take it to a store and let them do it. They have a soft counter top pad they set it on and press the back on with a hard disc like thing so it clicks in evenly... If you try it yourself , you will likely damage the crystal (glass you see the time thru).I know you thought you were doing an easy job yourself... but the jewlery stores would have changed it for the cost of the battery and not risked damage to your nice watch.
In order to replace the crystal on your watch you are going to have to remove the entire movement and use a watch press to remove the crystal. this is not an easy job and should be done by a professional First you will need to get a watch back opener to unscrew the back of your Tag. The three slots should fit into the back of the watch. tighten the opener until it is firmly on. then turn counter close wise until back of case comes off. Next you will need to remove the watch hand and crown. Becareful doing this for pressing to hard will break your set leveler. You will need a thin pin pusher and look on the back of the movement for an arrow pointing toward a hole in the movement. Push down and at the same time pull the stem and crown out of movement. turn the watch right side up and the watch movement should fall out. Place movement on a very safe spot so not to damage movement or dial now you will you be ready to remove crystal Since it is a friction crystal you will need to do use a watch case press . find two die that fit exactly the watch and crystal use a scooped side and place it on the bottom side of the watch press. Next use a flat die to place on top of the case press. place the watch face down. you will be pushing the watch crystal out from the top. Press down on the level and check to see if the crystal came loose, keep doing so till the crystal comes out. finally you will need to measure the thickness and diameter of the crystal and find the exact size. I believe this watch has a sapphire crystal so you will need a sapphire crystal too. Once you buy the proper crystal it is time to put the it in the watch. Place the watch face up in your watch press. and slip the crystal in through the top making sure its perfectly even all around. Slowly push down on the leveler until proper pressure is applied and the crystal snaps in. Now you have new crystal . Clean crystal thoroughly and the inside of the case. Place watch upside down carefully place movement back in. slide spacer in . Now slide watch stem and crown back in push down again on the set leveler with pin pusher. Place case cover on back and tighten properly to prevent water or moisture from entering and you are done. This repair should be done by a professional especially on such a nice watch. Any watchmaker can do this job and will have the tools to do it properly
Use a jeweler's loupe to identify all scratches on the watch crystal. You do not have to remove the watch crystal from the watch.
Use a polishing cloth to remove dirt, grit, lint or any debris on the watch crystal. Squeeze a small amount of standard toothpaste with abrasive properties onto the watch crystal. Gently brush the toothpaste into the crystal for five minutes. Wipe clean the watch crystal. and repeat another five minutes.
Use the jeweler's loupe to inspect your progress. Repeat application if necessary. Apply Brasso polish once the watch crystal is wiped clean. This will polish the crystal to a clear, bright shine.
Apply Autosol or Polywatch to the watch crystal in the same manner as toothpaste if you prefer to use a product specifically designed for watch crystals. These products will provide the same results as toothpaste. You may also apply Cerium Oxide, a glass scratch remover used specifically in the window manufacturing industry.
Apply a small amount of 3-micron diamond paste using your finger or a Kleenex if removing scratches from a sapphire crystal. Rub the paste in for about five minutes. Remove paste with cloth. Buff the sapphire crystal with one-quarter micron buffing diamond paste for finishing.
Use a toothpick to remove excess polish and gunk that may accumulate between the crystal and the bezel that secures the crystal in place. Gently work the toothpick around the diameter of the bezel. Wipe the bezel clean with a cloth.
Buff the watch crystal with a polishing cloth.
OR..take to a local jeweler/watchmaker.
Best regards. Jewel
mcdevito75 here, helloarcus, look for a small watch repair shop in your area in Hong Kong you shouldn't have any problems getting a new glass (crystal) for your calvin Klein watch, However since you say the watch is new, contact Calvin Klien and let them know of the broken glass, see if it's on any kind of warranty, the paper work with your watch should have the contact info.
mcdevito75 Here, hello vera, you won"t have any trouble finding a watch repair in MN USA I figure a watch Crystal (glass) could cost $25.00 To $40.00 depending on the watch itself, and if the crystal (Glass) is Glass, Mineral, or Plastic. You may save a little money In MN USA by going to a small watch repair center over one of the very big fancy Jewelers. Regards, mcdevito75
