Question about Activision Call of Duty Black Ops
Black ops cheats
In the DISABLE COMSAT SECTION of the game you have to escape along a walkway high above the valley floor this walkway gets blown up and you fail because you become seperated from the rest of your team. The problem is no matter how fast you move one member of the team stops in front of you and you cannot get past before the walkway gets hit by an RPG! How can I get though this?
Posted by Kevin Wardle on
Nikki Mclean
  • 293 Answers
Basically, you're supposed to jump past the broken section of the bridge and follow your squadmates to a jump point. In other words, you don't save Harris because you can't. From there, you get treated to an awesome base-jumping sequence.
Posted on Nov 04, 2017
1 Related Answer
Zhenya Ogorodnikov
  • 218 Answers
SOURCE: black ops cheats
Greetings,
For an extensive list of cheats, codes, and walkthoughs for Black Ops (PS3), visit this site. Thank you for using FixYa.
Posted on Sep 20, 2012
Waupaca 3 stop elevator. Power went out. Stuck between floors. How reset elevator to get to proper floors?
There should be an escape hatch above your head on the ceiling panel. Try that but be careful. If not, pick up that phone next to the floor numbers and call the fire department.
Dec 28, 2016 | Miscellaneous
How to do a search for plants along a walkway?
You can visually widen a walkway by planting a wider section on either side with low-growing plants, and graduating up to taller plants further back from the walk. A walkway that has 12" plants running along the side is going to "feel" narrower than one with low-growing sedum or groundcover stretching 2 feet beck on either side before blending into taller plants, which will feel wider. To search for plants to fit the bill, don't use search words that describe the walkway, but that describe the size of the plants you want. "Ground cover", "low growing", "creeping", for example.
Urban space products
Feb 14, 2013 | Sony Ericsson Walkman® W880i Cellular...
Both the egyptians along the nile river and the indians in the indus valley were known for their developement of medical practices. is this true or false
True, irrigation and medical institutions were developed by the Egyptians along the Nile and Indians in the Indus Valley.
Apr 28, 2011 | Video Game Consoles & Games
BMW X-5 2003 4.4i - valley gasket - coolant leak?
Yes this and many other problems can and do happen to this engine.
Apr 19, 2017 | 2003 BMW 5 Series
The last castle on level 8 at the end i keep running over the same stuff over and over so what do i need to do? super mario bro ds. please help!
when you're going through that castle there is a certain way you have to do it.
if you're going through the part with the gray blocks over the lava here's the order.
1. in the first area, you have to go the bottom walkway (mario will skip across the gaps) and you hear a little chime. that means you taken the right one.
2. after you cross the area i described above, you come across an area that looks like the last one. just take the very top walkway. you're 2/3 of the way there :)
3. this is the final area of this "maze". in order to continue use the CENTER walkway.
if this doesn't help, i am a huge ds fan. i found a complete walkthrough for the whole game at gamespot.com it is by DBM11085. i will also help with SM64DS, mario party ds and mario kartds. thx;)
Feb 19, 2009 | Nintendo DS Lite Console
Reaching birdman enemy
Try to keep him away from the walls otherwise you will have a harder time
attacking him. Do the same as you did previously until you finally defeat
him.
9. Wall run up to the button on the wall to the right and go into the gate
that opened up.
Scene
Note: If you have the Crowmasters sword you can make quick work of the
minions in this next room attack them with secondary attack (with triangle)
10. Wall run to the curtain to your right and it will automatically slide you
down it when you touch it. Fight or avoid the minions here. Face the wall
that you came down and climb up onto the stone slab behind you. Run up the
pillar to your left and then shimmy left. Climb up onto the ledge you reach.
Follow this walkway straight and then to the right. Wall run along the wall
to your left over the doorway and you should land on a narrow ledge. Drop
down (Circle) and shimmy to your left. When you reach the end drop down
(Circle) twice. Follow the walkway behind you and wall run along the wall to
the right to get over the gap. Go through the doorway up ahead and go to your
left. Be sure you have collected all the Artwork and picked up all the
weapons you could to add to your weapons gallery before continuing on because
you don't want to come back through this portal again (I say this mainly
because I have noticed that the game tends to get kind of glitchy when you go
back through a portal that you really didn't need to go back through). Follow
this path through a doorway of water. Use the fountain in this room to
heal/save and then go farther into the room.
Dec 11, 2008 | Ubi Soft Entertainment Prince of Persia:...
Activision Call of Duty Black Ops Logo
209 people viewed this question
Top Activision Video Game Consoles & Games Experts
Muntejaya Ginting
Muntejaya Ginting
ray gallant
Are you an Activision Video Game Console and Game Expert? Answer questions, earn points and help others
