The top thread does not pick up the bottom thread to be able to sew
SOURCE: singer sewing machine model 6012 c
hi
i want to know how i put thread in the sewing machine
thank you
SOURCE: bottom thread of sewing machine jams up
Try turning the bobbin around. Some bobbins should turn clockwise, some counter clockwise. What you described is what my Kenmore and Brother machines do when the bobbin is in incorrectly.
SOURCE: Top thread won't pick up the bobbin thread
re insert the needle, maybe you did not put the needle up as far as it is to go. Make sure the flat side of the needle is to the back of the machine. Without any thread in the machine hand turn the wheel and look to see if the hook of your bobbin would/could catch the thread (to see if timing is right)
then thread the machine and hand turn the wheel and see what it is doing.
Your timing might be off, but I do not think that is likely. Though it is possible that when the needle fell out, it hit something hard, broke, and pushed the machine out of timing. then you need to bring it in.
SOURCE: not picking up bobbin thread
Make sure that the needle is inserted with the flat side to the back and that you are threading the machine correctly. Be sure to turn the handwheel counter-clockwise, from the top towards you.
SOURCE: Singer Pixie - trouble threading bobbin
look at the bobbin direction. if it dont pick up that way, change the direction
