Question about Haier BC112G Wine Cooler
How to replace thermostat on Haier BC-112G
Where is it located
Posted by Donna Kreidler on
nexrace
    New Friend:
    Problem Solver:
  • 9 Answers
First lets find out why you want to change the thermostat.
  • The 112G has a control board & temp sensor
If you are having problems try replacing the sensor first then the control board.
Link to the parts breakdown page:
http://service.haieramerica.com/Models.aspx?CID=226#
The sensor is $4.76 & the control board is $26.81.
good luck,
dan
Posted on Apr 01, 2012
1 Related Answer
justinbur167
Justin Burnett
  • 257 Answers
SOURCE: NEEDED: manual for BC 112G wine cooler
Hello Ahanaples,
I understand that you are trying to locate a user manual for you Haier BC112G wine coller. I have located the manual on Haier.com the following link will take you to the page then you just have to click on the model of the unit that you have the first one at the top of the page.
http://www.haieramerica.com/en/support/modelsearch
Thank you for choosing FixYa.com
Justin Burnett
Posted on Mar 28, 2011
Where is the thermostat reset button on my Haier Dryer?
it should be on the thermostat itself but if it old model might not have one will have to replace it :) cheers
Sep 21, 2017 | Haier Dryers
Why My haier model hcm070la Chest freezer the compressor is not kick on
check thermostat, or relay on one side or back cclose to the compressor area there is a removable lid. removed and look for a thermostat disconect the 2 wires and bridge them then plug the the freezer on if runs replace the temp thermostat for a new one should be freezer thermostat
Nov 07, 2016 | Haier 7 cu. ft. / 198 liter Chest Freezer...
Where is thermostat located
follow the upper hose to engine at the end of the hose that houseing should house the termostat
Jul 01, 2012 | Haier BC112G Wine Cooler
Location of thermostat
follow the upper hose to the engine
Haier BC-112G not working
as stated already:
  • first replace the temp sensor: $4.76 from Haier RF-6250-01
Still have the dreaded 25 degree & LL in the temp box?
  • Replace the control board: $26.81 from Haier RF-0668-04
Oct 23, 2011 | Haier BC112G Wine Cooler
Hello Ahanaples,
Justin Burnett
Mar 28, 2011 | Haier BC112G Wine Cooler
My haier dryer quit. I replaced the thermostat located in back near the heating element and the thermal limiter. The dryer worked twice but seemed to get very hot. The on the third time it quit again. What...
Have you made sure the vent is not plugged, and that the vent fan is working properly? This would cause over heating. There is also a thermal fuse that caused it to quit again.
Sep 11, 2010 | Haier GDZ5-1 Electric Dryer
Haier wine regrig. to cold. How can you fix the thermostat control.
you can turn it counter clock wise to minimum. if it wont turn off the compressor, you can not repair the thermostat. just replace it with the same one. do not substitute. there are different types and uses of thermostat. i hope i was able to help.
Jul 05, 2008 | Haier Refrigerators
Haier beer dispenser model HBF05E
Either its not getting cold enough to shut off or your thermostate isnt working.. thats the only thing that cycles it.
Aug 27, 2007 | Haier (HBF05EAVS) Beverage Dispenser
Haier BC112G Wine Cooler Logo
831 people viewed this question
Top Haier Furniture Experts
John Tripp
John Tripp
jasbo
jasbo
Colin Stickland
Colin Stickland
Are you a Haier Furniture Expert? Answer questions, earn points and help others
