Question about HP LaserJet 5000n Printer
We are scaning an envelope to be printed and the letters are being printed as dots so it looks blurry.We printed the same scan on a Konica and it was fine. What to do? JOE
Posted by Joseph on
Vinaya Kumar Kuchipudi
  • HP Master
  • 1,121 Answers
Increase the DPI(dots for inch) in printer properties, check for the quality..
Posted on Feb 02, 2012
5 Related Answers
Bruce Eichhorst
  • 74 Answers
SOURCE: printing return address on #10 24lb regular envelope
Are you free hand addressing or are you using "Word - envelopes and labels" tool. It should be goof free. If you are, check the pull down rollers on that end of the printer for damage or contamination. When you lift up the cover like you're installing a new cartridge, you should see the black rollers. Clean them with a q-tip and alcohol, wiping across while rolling it with your finger. If you're not using Word, pull down the tools tab and select letters and mailings, then envelopes and labels.
Posted on Jun 30, 2007
Anonymous
SOURCE: Envelopes
I've found a similar problem to be an issue with a character that is misread by the PCL6 driver. I would uninstall the PCL6 driver (including from the printer server properties) and install the PCL5e driver in its place.
Hope this helps
Posted on Sep 16, 2008
Anonymous
  • 499 Answers
SOURCE: Photosmart D7460 will not print envelopes from Printshop 23
u should go to print setup in ur program then go to paper type which u want to use it then select "Envelop" instead of "A4"
Posted on Jun 14, 2009
jolaw11
jolaw11
  • 13 Answers
SOURCE: Print name and address onto envelope
Start by selecting the information, i.e,, highlight, then "CTRL+C" When you open the envelope window click into the address box, and use "CTRL+V".
In Word you simply select the information you wish to print, then click on the "Tools" tab, select "Letters and Mailings", and follow it to "Envelopes and Labels". When you open the last tab the information (address) will already be there.
Posted on Jun 19, 2009
Anonymous
  • 6 Answers
SOURCE: Printing Envelopes
There is a workaround for this problem by tricking the printer.
The paper sensor, on my printer model hp4500 seems to only sense the paper at the beggining of the print job.
What I did to trick the printer to print on odd size paper is slide the paper adjuster to 8.5 and put a regular white sheet in. Then put your odd size paper under it. When you print your document set the number of copies to 2 and print. The printer is going to sense that the paper is correct, and start the job.
Here is the tricky part... once the first 8.5x11 sheet is almost all the way through quickly slide the paper adjuster over to match the size of your odd width paper. The printer should pick up the odd paper and print the second copy. Fool you printa! You should be able to do batches of odd paper size under the first 8.5X11. I hope this helps.
Deny
Posted on Jun 27, 2009
Print envelopes 350
was the computer os updated, 8.1 to 10 or ?????
try this
Self Help Product Support Konica Minolta Business Solutions Inc
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jan 20, 2014 | Konica Minolta bizhub C351 All-In-One...
Need to pring envelopes on my konica Minolta hub 350 printer
Place envelopes in either drawer 1 (top drawer) or the by-pass tray. Generally, the envelope is placed side to be printed down. (On the printer you can set up custom envelope sizes.)
Select Print. Click 'Properties' for the printer. In the resultant dialogue window, set the printer to print to the 'envelope' print path.
Click OK, click Print. (test print direction first)
Check your printed envelope. You may need to change the orientation of the envelopes to print with the opening at the top.
Jul 30, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Paper pickup not moving
Have you set the margins?????
If you push the left margin over, it may help.
Jun 08, 2009 | Konica Minolta magicolor 2400 Laser...
Bends envelopes in printing
Most laser printers have an "S" paper path. They cannot help bending paper. I would suggest you print lables instead of envelopes if you send several letters. If you only send 1, hand address the envelope. Not elegant ut it works.
May 28, 2009 | Brother HL-2040 Laser Printer
When I print enveloppes with my Konica 2430DL, I get shadows, but not on other print jobs
When you look at an envelope, it has spots where there are 2 to 4 thickness of paper in spots.( folds of the envelope) If this is where your shadows are, and your printer does not have any settings for envelopes, your printer may not be able to print those types of envelpes. You might try a lighter and thiner envelope.
Mar 03, 2009 | Konica Minolta magicolor 2430 DL Laser...
Printing envelopes
Open a MS Word Document, select 'Tools' then 'Letters and mailings' then 'Envelopes and labels...'
Envelopes and Lables dialogue box opens - ensure you are on the 'envelopes' tab
Then type your recipient address in the larger white box
for standard letter envelope (DL 220m x 110mm) - Insert envelope into Brother HL-2030 manual feed, with print side up, gummed flaps down and to the left side (bring gray plastic guides in close to secure).
Then select print.
I have found that during the feed, one end of the envelope gets a little bit crumpled but overall it's still a little bit more professional looking than my handwriting.
Jan 12, 2009 | Brother HL-2030 Laser Printer
How to print the envelope on a different printer from the letter?
Sure. Select the Office Logo (the big circle on the top left) and then choose: "Print>" You will be able to select the printer, and then choose: "Current page." Move to the next page, and repeat the process, choosing the preferred printer.
Hope this will FixYa.
Sep 22, 2008 | Microsoft Office Professional 2007 Full...
Envelope printing
Microsoft Office Word will help him with that, AND keep a record of his projects. Just pick Tools/ letters and mailings/ envelopes and lables.
May 23, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
The filmholder stop under scaning ?
According to Konica Minolta the driver you are using is not Vista compatible. You might look into downloading VueScan http://www.hamrick.com/ which will allow this scanner to work in Vista.
Feb 24, 2008 | Minolta Dimage Scan Dual II Film Scanner
Scaning documents
Try and alter the contrast settings. If the scanner does not pick up 'data' including folds, you'd blame it for non-performance!
S. Mohan. India
Oct 21, 2006 | Kodak i40 Path-Through Scanner
HP LaserJet 5000n Printer Logo
32 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
