Hi. The r4i gold card has worked fine in my dsi and then all of a sudden doesn't save the games. It has 50 games in it and I can't save none. It works fine, I can play all the games with no problems but when it comes the time to save... it gets stuck and I have to press power off. If anyone knows what could be the problem and how could be fixed (if could be fixed) I'd be grateful.
SOURCE: r4i gold doesn't work at my brand new dsi!!!! help!!!
dont use a 8 gb! a 2 gb may be the only working solution
SOURCE: DSi R4i Gold card is stuck on loading screen.
hi just noticed your message i had a 4 gig card and it kept saying loading .now changed it to a 2 gig card from argos and all works fine now hope this helps jay
SOURCE: Hello. I just bought a dsi and a r4i card but the
I have this issue also and i only bought mine last week. I have a DSi and the card is for a DSi. During glame play it froze so i turned it off and back on and then its saying theres no card inserted in the DS Game card slot.
I have a DSi version 1.3A <does this make a difference?
It was working fine before.
SOURCE: R4DSi
First check for your firmware version, look in the settings, the version number is shown there on the top screen, right at the bottom, because the latest firmware version blocks the R4DSi.
Latest Firmware Made by Nintendo for the NDSi is v1.4
If you still using firwmware 1.3, download the latest kernel for that flash adaptor.
Connect the memory card with a card reader to your computer, backup all .nds files to your computer and format the memory card.
Unpack the latest kernel to the memory card afterwards and put the .nds files back to the card, these files are the games.
Succes.
SOURCE: r4i gold not working on dsi
Two reasons for this, one you have a bad card, the other is you have not put the right software on the card, or have not put it on right, did the software come with the card or did you download it yourself, just go to infox.domain, and download the software for you card, if that dont work, you have a bad card, send it back and ask for a good one.
