Question about Stanley Utility Knife
Load blades on stanley 10-499 - Stanley Utility Knife
1 Related Answer
chrisvarns
SOURCE: how to load blades on stanley #10-788
This knife is ****. To load... you have to push the slide all the way forward. Make sure the switch is set to unlock. PINCH THE BLADE WITH YOUR FINGERS AND WIGGLE IT INTO PLACE. Then you have to use every ounce of thumb power to relock the switch.
Once you are done, the blade will still come out in 9.9 / 10 times you cut something.
Posted on Jan 06, 2011
Have a Stanley Fat MAx utility knife and unable to open it to load the blade
there is a little black button on the end where the blade comes out. With the blade in the out position,push in the button and pull out the blade. With button pushed insert new blade or turn the old one around to use the other end.let go of the button and you are ready to go.
Jun 26, 2011 | Stanley Utility Knife
Loading instruction to change blade on Stanley FatMax box cutter
Hmmmmm.... that sounds really confusing.
Better yet... just watch this video! http://www.youtube.com/watch?v=B8Q1p-8jkyE
It's actually pretty easy! :)
May 03, 2011 | Stanley Utility Knife
Cant put the thing back together after putting in new blade !!!fat max knife
some stanley knifes require stanley blades only, or make sure the clip blade is in is seated in the grove completely.
Dec 23, 2010 | Stanley Fatmax Xtreme Retractable Utility...
How to load blades on stanley #10-788
Nov 08, 2010 | Stanley Utility Knife
How do you load a new blade?
At the back end of the knive (the curved end) press the black piece through the yellow rounded part and the yellow front and the black back will part, now slide the yellow part back to reviel the blade folder. Fit new blade then refit the yellow part on top of the black part and slide the yellow part foward to lock it back in.
Jul 31, 2010 | Stanley Utility Knife
Just purchased a Stanley FatMax 10-778 retractable knife. Cannot figure out how to load the blade for use.
1. Make sure the side lock is unlocked.
2. Push the thumb tab all the way to the front of the blade handle.
3. Insert the blade in the opening, you may notice two notches on the top side of the blade.
4. Press the small blade release button as you slide the blade into the knife. You may have to jiggle up and down to get the two notches on the blade fully into the handle.
If properly inserted, the exposed area of the blade should look very close to an equilateral triangle.
make sure both notches of the blade are inside the handle. They notch into the thumb lever.
good luck
Mar 20, 2010 | Stanley Fatmax Xtreme Retractable Utility...
Stanley 10-788 how to change blade
Push the top metal button all the way foward as if pushing the blade out to it's (farthest) 3rd setting. Then push foward and down one more time which locks the mechanism down. Push and hold the yellow side button as you insert the blade. When the blade locks in all you have to do is release the yellow button and return the top slide to it is fully retracted home. The blade is loaded
Jan 14, 2010 | Hand Tools
WAS ABLE TO OPEN THE STANLEY SWIVEL LOCK UTILITY KNIFE AND REMOVE DULL BLADE. NOW i CAN'T GET THE NEW BLADE IN AND CLOSE THE KNIFE PROPERLY, WHAT'S THE TRICK?
If you use the wrong brand of blades, they won't let the knife shut all the way. The notch is cut slightly differently. The same is true for the Kobalt knife I just bought at Lowes. Get the Stanley blades that are right next to the knives - they are the only ones that work.
Sorry.
If you bought the Stanley blades, then I don't know what the problem is. Sorry for that too.
Nov 20, 2009 | Stanley Swivel - Lock Fixed - Blade...
Stanley knife blades fell down drum and under
Probably the best thing to do in this situation is to empty the washer out, then unplug it and turn the water off at the spigot.
Then invert the washer, leaning it back, so as to reach the blades under the drum.
Mar 04, 2009 | LG WFT1071TP Top Load Washer
Stanley  Utility Knife  Logo
1,839 people viewed this question
Top Stanley Cutter Tools Experts
efs_perpends
efs_perpends
Joe Garcia
Joe Garcia
JOHN LAPIER
Are you a Stanley Cutter Tool Expert? Answer questions, earn points and help others
