Question about Hitachi Televison & Video
How do you fix the color to a model 43fdx11b hitachi
Posted by zack krlav on
Alexander Moore
    Novelist:
  • 181 Answers
Hello!you mean: colors out of convergence? nothing you can do about that, unless you replace 2 convergence amplifiers I.C. chips, plus all those burned 1 watt low ohms resistors with exact values, which only could be obtained via service manual or schematics. After resistor is burned, there is no way to read color code properly, due to partial evaporation of pigments. this is a "pro" job. If you try or tried, already to converge those "stubborn" crosses, there is more to do, even after you removed and replaced two 20 pin I.C. chips, soldered dead into sweep module, plus located and replaced resistors with precise values, you need to get your settings back to normal, by going into "factory service mode' or, at least into "convergence alignment" menu and fight with those crosses!Don't forget the white "****"! Otherwise, you will be re-servicing your set all over after 30 days of usage.good luck,Alex.
Posted on Feb 01, 2012
4 Related Answers
e-Guru
e-Guru
  • 3917 Answers
SOURCE: hitachi model 43fdx11b power light come on no
Hi
The set has failed in either the high voltage section or the deflection amplifiers. These are the most common because they draw the most power. Of course, it could be other failures as well it is indicative of overloaded power supply current and the protection circuit going into action to shut down the set. Also this has been an issue with the convergence IC's failing. But in both case you will need to have a technician replace those if needed or to diagnose it and find out the exact cause and do the repairs.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Apr 20, 2011
Anonymous
SOURCE: Hitachi Model # 43FDX11B. Will not power
Mine just developed the same problem.. did you find a solution/fix?
Posted on Aug 09, 2009
Lashawn Robinson
  • 1153 Answers
SOURCE: Hitachi 43fdx11b rear proj tv
you can check at vancebaldwin.com or ctechnicians.com
Posted on Jan 04, 2008
Slinteriors
Sonny Berry
  • 8617 Answers
SOURCE: Hitachi rear projection TV Model 43FDX11B with
You will need to install a convergence repair kit. You can get the repair kits with instructions at www.tvrepairworld.com
Posted on Sep 22, 2010
I have the Hitachi Model # 43FDX11B Date Oct. 2001, I can not get the TV to turn on when I turn then power on. The only thing it does is flash a red light down by the power button. What do I need to do to...
hello, the red light is flashing because theres a fault with the tv count how many times the light flashes the this gives you an error code then do a search on google or get back to me i'll try and tell you the fault and possible fix
regards
shaun
Nov 24, 2010 | Hitachi 43FWX20B 43" Rear Projection...
Hitachi rear projection TV Model 43FDX11B with convergence problem
Sep 21, 2010 | Hitachi Televison & Video
I want to know the wattage for Hitachi 43fdx11b
225 normal up to 265 watts for high brightness scenes.
When the set is off it draws 2.7 watts
Sep 25, 2009 | Hitachi 46F500 46" Rear Projection...
Jul 09, 2009 | Hitachi 43FWX20B 43" Rear Projection...
CONVERGENCE BOARD PROBLEM?
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem. Doing so will only make things worse. The blog does however show you how to fix other common problems with these sets.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Nov 06, 2008 | Hitachi FDX Series 43FDX10B 43" Rear...
Hitachi 43fdx11b
Hello Hitachi,
By me, brown,black,gold gold is one ohm, namely 1 for brown, black for zero and the rest for quality!
TOMMIX
Jul 15, 2017 | Televison & Video
Looking for convergence part number
yes they are the same Convergence ICs number STK392-110 you need to replace both ICs. You can get replacement ICs at the following link and they provide free instalation instructions with pics so you can do the job yourself. Heres the link.
http://servicemanuals.vstore.ca/
May 12, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Stk392-120 hitachi 43fdx11b
Stk392-110,-120 and -150 are replaced with upgrade IC's....
Stk394-160E = use kit # X 480293 ( has two in kit = replace both)...................T.
Apr 21, 2008 | Hitachi FDX Series 43FDX10B 43" Rear...
Jan 04, 2008 | Televison & Video
Televison & Video Logo
49 people viewed this question
Top Hitachi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
