When I try to copy photos, either black and white or color, the completed copy has a bluish cast. The printer says it has enough ink in both cartridges; however, the color cartridge is lower in ink than the black cartridge.
Replace color cartridge:Reason: Color cartridge carries three color for color combination, in that any one of color empty or dried up color combination wont happen perfectly, result printer get mismatch colors.. In your case it might be magenta color over.. replace color cartridge to get good print outs..
Testimonial: "When I checked the ink levels it said the ink was still satisfactory; however, I replaced the color cartridge and things worked correctly. Thanks"
SOURCE: My HP LaserJet 2605dn is printing pictures with a bluish tone
1. If you have checked Economode setting (sam88kid), and still have problem.
Run cleaning page off printer, then do color calibration, follow up with configeration page. If you still have the problem, your last resort may to try the Cyan toner in another printer.
Next you should contact HP helpline direct as the cyan toner should be considered defective and should be replaced under warranty, either directly by HP or through your suppling retailer.
Cheers:DeJudge.
SOURCE: Vertical streaks on printed photos on HP2710 all in one
New cartridges often need a few prints before acting good. Try to clean the heads of the printer also. If the problem consists maybe you need new cartridges.
SOURCE: Printer has not been used for 2 yrs. I use it to make copies.
I'm sorry. The printer needs both cartridges (which holds the ink) and printheads (which distributes the ink) as well as the scanner to copy a page for you, since even copying is a print job.
//Al
SOURCE: hp 3180 print cartridge light blinking
hi,
is the ink cartridge you replaced hp brand or did you refill it this is an incompatibility code from the software. some brands and cartridges are not fully compatible and creates an e code error code. if it is hp brand it is likely a defective sensor chip in the ink cartridge. i would for best assurance return the cartridge for a different one and then recheck. if niot you may need to restore your software or reinstall it most of the time this will fix the problem.
hope this helps..happy computing!
