Question about AOpen DUW1616/ARR DVD RW Dual Layer Burner
Can I open a jammedDUW1616/ARR DVD
THis product is jammed with something currently in it. All screws are removed.....Can I get internal to remove jamming CD?
Posted by ittleself on
Stuart
  • 807 Answers
Look on the front of the tray where the eject button is There should be a small round hole, this is for ejecting a stuck disk. Just open out a paper clip and insert in to the hole and press until the tray opens.
Posted on Feb 04, 2012
How to open a stuck CD drawer in Marantz UD7006?
The Marantz UD7006 has an internal cover over the CD/DVD mechanism that is hard to remove. There is a square black plastic part in the left corner that protrudes through. Get something to hook that corner an gently bend it out far enough to clear that corner to remove. You can push back in to rescrew cover back down. You might have to cut the white caulk on foam block and remove it too. I slid the lens mechanism back and forth a few times on its rail.
Jul 23, 2014 | Marantz UD8004 Universal Disc Player...
3 year old jammed dvd in bluray. How to get the dvd out and restore operation of machine
A DVD should fit without a problem in a blue ray player; but I suspect your use of the word "jammed" indicates something beyond it fitting of not.
Two possibilities: easiest is to find a small unmarked hole somewhere above the tray (assuming it has a tray) where the disc enters the unit. With the power off, insert a long straight pin (opened paper clip works) into the device until you feel a slight resistance. Press just a bit further and you should see the drawer begin to open (don't force it). Once the drawer begins to open, remove the pin and plug the unit in. Hopefully you have now engaged the mechanism that will allow the disc to eject.
If you cannot find the hole, or if this doesn't work, you'll have to remove the cover to get to the mechanism. This is usually a handful of Phillips head screws on the sides and back. If you Panasonic often marks the screws that remove the cover with a small arrow next to the hole to aid in disassembly.
Sep 11, 2013 | Panasonic Televison & Video
DUW1616/ARR DVD Jammed
Can't you just push an opened out paper clip in to the eject hole on the front of the tray cover. It should be just above the eject button.
Jan 31, 2012 | AOpen DUW1616/ARR DVD RW Dual Layer Burner
Paper is always jamming
Clear the jam from the back of the All-in-One Follow these steps to clear the jam from the back of the product
  1. While the product is still on, disconnect the power cord from the back of the product.
  2. Press in the tab on the left side of the rear door to release the door. Pull the door away from the product to remove it.
    1. Gently pull the paper out of the rollers. CAUTION: If the paper tears, check the rollers and wheels for torn pieces of paper that might remain inside the product. Remove all the pieces of paper from the product to prevent more paper jams.
    2. Replace the rear door. Gently push the door forward until it snaps into place.
    3. Connect the power cord to the back of the product.
    4. Press the OK button to continue the current print job
      Clear the jam from the front of the All-in-One If you cannot remove the paper jam from the back of the product, follow these steps to remove the paper jam from the front. CAUTION: Remove the paper jam carefully because it is possible to damage the product when removing paper from the front.
      2. If necessary, pull the input tray down to open it, and then lower the print cartridge door.
        1. Gently pull the paper out of the rollers. CAUTION: If the paper tears when you are removing it from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the product. If you do not remove all the pieces of paper from the product, more paper jams might occur.
        2. Close the print cartridge door.
        4. On the control panel, press the Start Copy Black button (c01495311.gif ) to continue the current print job.
          Step three: Perform a power reset Follow these steps to reset the product.
          1. Press the Power button (c01602202.gif ) to turn on the product.
          2. With the product turned on , disconnect the power cord from the rear of the product.
          3. Unplug the power cord from the wall outlet.
          4. Wait at least 15 seconds.
          5. Plug the power cord back into the wall outlet.
          6. Reconnect the power cord to the rear of the product.
          7. If the product does not turn on by itself, press the Power button (c01602202.gif ) to turn it on.
          Step four: Clean the rollers
Mar 30, 2011 | HP Photosmart C4180 All-In-One InkJet...
My DVD Burner will not open but it shows a red light which leads me to believe that it works but there is a problem with how it is connect or maybe it is an internal problem.
Hi there, you should probably try to open the burner manually, to do so, usualy there is a small hole on the from that you should push with a pin and this will open the dvd. Sometimes the dvd can get stuck if it is not centered perfectly. Thanks.
Mar 09, 2011 | AOpen DUW1608/ARR (914ID37002) DVD±RW...
Help please, I've a paper jam. how do you open the printer ??
  2. Press in the tab on the left side of the rear door to release the door. Pull the door away from the product to remove it. Figure 1: Remove the rear doorc00652174.gif
  3. Gently pull the paper out of the rollers.
  4. Replace the rear door. Gently push the door forward until it snaps into place.
  5. Connect the power cord to the back of the product.
  6. Press the OK button to continue the current print job.
    NOTE: The print job might cancel instead of print. If this happens, reprint the document.
  • If the issue is resolved , you do not need to continue troubleshooting.
  • If the issue is not resolved , continue with the steps in this procedure.
  2. If necessary, pull the input tray down to open it, and then lower the print cartridge door. Figure 2: Print cartridge doorc01491485.gif
  4. Close the print cartridge door.
  6. On the control panel, press the Start Copy Black button (c01495311.gif ) to continue the current print job.
  • If these steps resolved the issue , there is no need to continue troubleshooting.
  • If the issue persists , see the next step.
For more info, you can click the link below:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00651302&tmp_task=solveCategory&lc=en&dlc=en&cc=us&site=null&lang=en&key=null&product=1141647
Feb 15, 2011 | HP Photosmart 4180 All-in-One Printer
DVD won't play and door won't open
Since you purchased a Bose system, I can only assume that you know nothing about electronics.  Therefore, I would suggest you take it to a repairman rather than try to open it.
Or, you could just buy something that isn't Bose for 1/10th the price and get twice the quality.
If you must be adventurous, you can open the unit and try to figure out what is jammed up and manually remove the DVD.  Again, if you know nothing about electronics, this could get you very hurt or killed.
Jul 08, 2009 | Bose 3 2 1 GSX System
Won't Eject or play DVD...just reads E 27 00
The problem is likely to be a jammed disk. All you need to to do is remove the cover by removing the 7 screws locking it on. The jammed disk will most likely be located where the dvd is read, this can be tricky to remove so carefully remove a screw at a time from the disk positioner (device with white disk on it, not 5 disk tray) gently trying to remove the disk after each screw is removed. The fewer screws removed the better. Usually only the screw on the right side needs to be removed to give rome to remove the disk.
Apr 03, 2009 | Sony DVP-NC600 Multi-disc DVD Player
Tne dvd door will not open
These are instructions to open door if DVD is jammed or the DVD recorder wont open.
Unscrew the 7 cover screws and the 2 foot screws. Remover player cover.
Pry the front control cover off from the top of the player and not the bottom with a thin screw driver paying attention not to crack or break the tabs. Just lift them enough to clear the hooks.Then lower the cover withut removing it so you can gain access to the DVD front internal bezel.
On the left side of the DVD recorder there is a notch with a lever in it. gently push on it as this is the release for the DVD door. Remove DVD from tray and close.
Re-install all covers and screws. Machine should work after this.
Jan 17, 2009 | GoVideo VR2940 DVD Recorder/VCR
DVD stuck/jammed in tray
there may be two screws on the top of the tray that holds the rounded magnet, the one that is placed to hold the disc when spinning, remove it, you can then simply take the disc out.
May 19, 2007 | Pioneer DVR-810H DVD Recorder
AOpen DUW1616/ARR DVD RW Dual Layer Burner Logo
Top AOpen Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Gustavo Ortiz
Gustavo Ortiz
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
