Question about Xerox Phaser 6180N Laser Printer
How to turn off replace fuser on display on xerox 6180
PrintDocta
    Novelist:
  • 217 Answers
The message is caused by the fuser having had 100,000 pages or so through it.
It will be pretty much worn out, and should be replaced.
The transfer belt also has a similar pagecount limited life, and also the pickup/separation/transport rollers would benefit from replacing (they can get 'flat spots' on them
Posted on Nov 25, 2015
3 Related Answers
Anonymous
  • 53 Answers
SOURCE: Receiving Fuser Failure error message
please check if the fuser is inserted properly:)
Posted on Nov 20, 2009
DrWho_64
Mark Cannistraci
  • 35 Answers
SOURCE: my xerox 6180 seems to overheat when I print
Your Fuser is most likely the issue. Make sure that it is seated correctly and that ALL of the packing tape was removed from the unit. Many items inside the printer are taped in place for shipping. If you missed one of them, it can cause a bunch of issues, like paper jams or the paper not getting close enough to the fuser on the way out.
It's normal for the printer to get warm when printing color. The extra colors have to be fused individually. So if it's a 6 color, color printer, then the fuser will be on and heating 6 times as much. I would check to make sure you are using the correct weight paper as well. Some papers may be too heavy (30lbs. bond vs. 20lbs. bond) to pass through the rollers correctly and cause paper jambs.
This really sounds to me like a issue with the fuser not being installed correctly. Make sure it is locked in securely to it's mounts and that 1 of its mounts isn't flopping around. Even if it's just a little loose it will mess up the paper path and not fuse the toner to the paper. Also, some types of paper wont take toner at all! This is because it might be Photo Inkjet paper with a semi-gloss or glossy finish. There is usually a way to hold the door open and run a test print to see where in the printer it's jaming and you can see if it gets close enough to the fuser to bond the toner or not. I have a feeling that's where your issues are coming from.
Try taking all the toner cartridges out as well as the paper trays and the fuser n(if it's not built into the toner carts themselves. IF THE FUSER IS BUILT INTO THE CARTRIDGE, please be careful when checking the fuser wire and do not to touch or breathe the toner dust. IT'S VERY BAD FOR YOU!!! Cancer kind of Bad! If the fuser IS built into the toner cartridge, make sure the cartridges are all fully seated and run a test print with the correct weight paper. 24lbs bond is pretty safe weight to work with, as 20 pound paper may be too thin and the printer is having problems grabbing and passing the paper into the next part of the printers paper path. And NEVER use compatible toner carts. I say that because the toner cartridges are used and fusers have a limited life-span and may be defective now. Test it with the REAL toner carts from the manufacturer and see if that fixes the whole problem.
BTW, you're not saving anything by using those rebuilt toner carts. In fact, if you look at all the problems you're having now and how much time and money that have been wasted on bad copies and paper jams, you'll see that refilled toner carts wind up costing you more than if you had paid the extra few bucks for the reliability factor.
Hope this helps
Posted on Jan 15, 2010
Testimonial: "thanks for your help - that's all really useful information. It could well be the way the fuser is seated. Thanks again"
Jeffrey McDaniel
  • 669 Answers
SOURCE: Xerox Phaser 6180 keeps saying load papertray with
Remove the paper tray and check the guides. Make sure they are lined up on the 8.5 X 11 marks. If it is lined up, try going into the menu of the printer and reset back to defaults.
Posted on Jul 21, 2011
My Xerox phaser 6180 keeps saying there is a jam at exit. Open door A. I have taken it apart & cleaned/cleared everything I can. Any suggestions?
This could be some paper still stuck in the fuser, so check that.
The usual cause of this, is the 'paper out' sensor arm (in the fuser) being broken.
I'm fairly sure that this is NOT available from Xerox as a spare part, so the quickest, easiest solution is to replace the fuser.
Jul 21, 2015 | Xerox Office Equipment & Supplies
Want to know life expectancy of the 6180
a new fuser should be a lot cheaper than a new printer
Mar 26, 2014 | Xerox Phaser 6180N Laser Printer
Clean printheads on Xerox phaser 6180
This type of print quality defect shows up if you have loaded the wrong type of paper in your machine and didn't remember to change the paper type (plain paper, card stock, labels, etc.).
This can also happen if the paper has a high moisture content, or if the humidity in the room is too much. Also make sure the room temperature is within its normal operating range (not too hot, not too cold).
The problem you describe could also be caused by using non-Xerox toner/drum units. Compatible toners don't work very well in Xerox printers.
Aside from those problems, the only other thing would be if the Fuser Assembly is near the end of its life...it will also cause some print quality problems like you are describing.
Dec 24, 2013 | Xerox Phaser Office Equipment & Supplies
My phaser 6180 color printer, toner not adhering to paper
hi.it could be your print cartridge.end of life.and very costly
Nov 19, 2013 | Xerox Phaser 6125 Laser Printer
OUR PHASER 6180 PRINTER IS SHOWING FUSER LIFE AND TRANSFER LIFE NEEDS REPACING SOON. WHAT ARE THEY AND WILL IT COST MORE TO REPLACE THAN BUY A NEW ONE
Go to this WEB site for fuser parts.
http://www.sparepartswarehouse.com/Xerox,Phaser,6180,6180N,Printer,Fusers.aspx
Go to this WEB site for transfer belt part.
http://www.fastprinters.com/ProductDetails.asp?PARTNO=XER-675K47088
May 16, 2011 | Xerox Phaser 6180N Laser Printer
I have a Xerox Phaser 6180 MFP, and it keeps saying paper jam and there is no jam, what can I do?
Check the fuser for paper stuck in it.
Check that the 'paper out' sensor arm (in the fuser) is not broken. If it IS broken, you'll need a new fuser.
Sep 03, 2010 | Xerox Phaser 6110 Laser Printer
My phaser 6180 transfer life repalce soon what is
If your Xerox Phaser 6180, 6180mfp, 6280, or 6280mfp is displaying "Replace Transfer Unit" or "Ready transfer Unit Life" you most likely need to replace the transfer unit.
For the 6180 and 6180mfp the part number is 675K47088. For the 6280 and 6280mfp the part number is 675K70583.Here is a video that shows you how to replace this part. It is very easy and requires no tools.
Mar 30, 2010 | Xerox Phaser 6180N Laser Printer
XEROX PHASER 6180 SAYS PAPER JAM, I CLEARED PAPER JAM, PUT IN NEW CARTRIDGE, AND IT STILL SAYS PAPER JAM
Mar 16, 2010 | Xerox Phaser 6180N Laser Printer
I have a Xerox Phaser 6180. I have not had any
You more than likely need to place a service call.
Over temp can be related to the fuser control circuits,
Don
Dec 15, 2009 | Xerox Phaser 6180N Laser Printer
How to replace the waste container in phaser 6110?
The easiest way I can tell you is this.
GO to Xerox,com, click on support and drivers.
THen the search box comes up type in phaser 6180, then enter, when the next screen displays click the support line for the 6180, In that search boc type in replace waste and step by step directions with photos come up,
Its the best place to go to find that information.
Jul 18, 2008 | Xerox Office Equipment & Supplies
Xerox Phaser 6180N Laser Printer Logo
93 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
