Computers & Internet Logo
Jerald Wolotka Posted on Jan 31, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dvd burner wont eject
My dvd player wont eject
jimod4343116
Level 1:
New Friend:
  • Contributor 17 Answers
  • Posted on Dec 15, 2014
jimod4343116
Contributor
Level 1:
New Friend:
Answers
17
Questions
0
Helped
5760
Points
32
Sometimes the hook that retains the tray will not release unless the tray is pushed inward slightly while trying to eject - poor design.
Anonymous
Level 3:
  • Master 807 Answers
  • Posted on Feb 04, 2012
Anonymous
Master
Level 3:
Answers
807
Questions
Helped
232228
Points
2344
Open out a paper clip and insert it in the little eject hole on plastic tray cover and push gently until it ejects.
5 Related Answers
Anonymous
  • 72 Answers
  • Posted on Aug 03, 2006
SOURCE: Dvd player has trouble reading the discs this dvd writer burns
Just for fun you could try a different type of blank disc such as memorex. or even if it does burn plus and minus try swithching the media you record to either plus to minus or minus to plus. You get the idea. This is if the firmware upgrade suggested by the other person does not resolve your issues.
Anonymous
  • 8 Answers
  • Posted on Aug 05, 2007
SOURCE: My new DVD-burner keeps ejecting
Try to solve the problem by looking into your PC. What all softwares have you installed? Are you having the problem when you are using some CD/Audio Players ( Does that program crash/hang usually ) ? Only install softwares that you think are useful. It can also be some maicious software. Always update you anti-virus AND anti-spyware. Uninstall all the unwanted softwares. If these dont help solve the problem,... I may help you if you could do the following steps. * When the problem occurs, open Windows Task Manager by pressing Ctrl, Shift, Esc together. * Under processes, note down the names of all the processes along with username and maybe memory usage. * Give all the particlars about your PC and post it to me ( Try "everest" from www.lavalys.com to prepare a report ). I shall look into the problem and try to help you.
Anonymous
  • 262 Answers
  • Posted on Aug 26, 2008
SOURCE: i o magic external dvd burner wont work
most likey it is incompatlable with vista ? did you check the specks lala linda
Anonymous
  • 105 Answers
  • Posted on Nov 24, 2008
SOURCE: need drivers for hitachi model gsa-h21n dvd burner
drivers are not needed in order to cd to work, but this problem has aleazrdy been registered.
you shoul click on START, RUN, and type "regedit"
then search in the tree the branch
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
in this, remove the Upperfilters & Lowerfilters values.
reboot, it should work
if really not working after that, download and install the firmware update you can download at http://drivers.softpedia.com/get/FIRMWARE/LG/LG-GSA-H21N-Firmware-A03.shtml
Computer Links
  • 2386 Answers
  • Posted on Feb 10, 2009
SOURCE: when i try to burn on hp1040e dvd burner it wont recognize the dr
you may not install the proper drivers of your burner, install it again and use some other burner application like nero cd burner etc.
I burned a dvd and now won't eject and system now says no dvd burner found. I need help to eject dvd and get burner recognized again
There may be a problem with the dvd you are using. If you look at the front of the dvd player there should be a very small hole. Take a paper clip and insert into this hole which should open the dvd drawer.
Now try another dvd to the if the player functions correctly. If not it likely means that there is a problem with your dvd player.
My cd burner wont eject
Enable the check box to eject in cd burner software
3helpful
DVD player wont eject
Try Turning the unit off and then back on. As soon as you turn it back on push eject .
2helpful
2answers
My LG multi dvd writer lightscribe tray wont open. the green light is steady. no matter how many times i try to eject the tray ang it wont open. there is dvd+r inside.
use a unfolded paperclip and insert it into a small hole below the disc tray. This is the manual eject port. Stick it straight in and push, a little bit of pressure will be needed.
BURNER WONT EJECT
find a small hole a very small hole just only a piece of paper clip try to push using it.
CD/DVD won't eject, won't play, Device Manager doesn't recognize.
If it's only 8 months old, then you have atleast 4 months left on your warranty. The problem will either be the ide controller channel or the dvd drive and firmware has faulted, the same fault probably happens when you have put a dvd in and it wont read or eject. Return to the place of purchase, where the drive should be replaced or the notebook exchanged.
Top Lite On Computers & Internet Experts
Steve Pack
Steve Pack
Larry Ng
Larry Ng
Are you a Lite On Computer and Internet Expert? Answer questions, earn points and help others
