Question about Dell Inspiron XPS M1710 Notebook
Invalid configuration information
It wont boot Every time i want to start it only says invalid configuration information - please run setup But i cannot access the Setup either by pressing F2 It only shows me the same error.... I have also removed the CMOS Battery because waited an hour put it back but also the same failure happened I cant boot please help
Posted by ark_626 on
5 Related Answers
sheila skaggs
  • 383 Answers
SOURCE: Invalid Configuration information
Windows Registry help First, get the computer to a MS-DOS prompt. Information about how to get to a ... that contains information about the current configuration of hardware ...
FTP information and help
Information about FTP and its commands. ... If you are unable to connect to any address, it is likely an issue with the network or computer configuration. ...
Device Manager information and help See our overview section for additional information on how you can get into ..... but the configuration information in the .inf file is set to hardwired. ...
Good Luck, Please dont for get to Vote.Thank you
Posted on Dec 14, 2007
Anonymous
SOURCE: No boot device available
I am using the dell system at XPS710 and i kept getting the bios error:
I tried to hit F1, then i get that message again. I hit F2, then it i didn't see the problem.
PLEASE HELP! 16x16_smiley-mad.gif No ignores!
Posted on Sep 25, 2008
Anonymous
SOURCE: Dell latitude C610
From the Bios, load all the default settings and then check the bios SATA port settings. If it is set to AHCI, change it to IDE to boot from Hard Drive. This should solve the problem
Posted on Oct 01, 2008
Anonymous
  • 16 Answers
SOURCE: Forgotton Configuration Passwordd of Dell Latitude D600
Unfortunately the only way to do this is by removing your battery from the mother board.
When i am refering to the battery , i mean not only the normal battery which you can un hook and rehook again pretty easily but the one from the interiors of the laptop its called a CMOS battery. Befefore you go opening up the laptop physically make note of the BIOS settings, as these changes will be wipped out when you remove the CMOS battery
Refer to the dell documentation that may have come with the laptop as to how to open the laptop physically.
You can also try if you can override the BIOS by upgrading it from the Dell website. (Although this may not work)
Best of luck
ksb
Posted on Jun 30, 2009
RescueTechLA
RescueTechLA
  • 2653 Answers
SOURCE: Dell Ispriron E1505 has a display message, invalid
Try removing both memory sticks and then booting up with just one installed. The bios should notice a shift in the amount of memory and prompt you to enter the bios.
Let me know if that works.
Posted on Dec 02, 2009
I removed my battery from my Dell Dimension desk top, waited and then put battery back in and started my computer.
When you removed the battery your computer lost all of it's configuration settings. You have to go into the set-up menu and and select the devices that are installed on your computer. Such as floppy drive, CD drive, DVD drive. Also have to set date and time.
Oct 08, 2014 | Dell Computers & Internet
Cant set up
You need to insert the CD/DVD that came with your computer and boot from that.
Apr 24, 2013 | Dell Latitude D600 Notebook
Start your computer and after the BIOS screen disappers , begin rapidly pressing PF8 until the Windows Boot Options appear. You should see "Safe Mode", "Boot from last valid configuration", and "Normal Mode", and maybe a few others. Select "Last Valid Configuration." Computer should sucessfully boot.
Jan 17, 2012 | Microsoft Windows XP Home Edition...
Please run setup invalid configuration information
If this error message comes up when you boot up the computer, it means the BIOS requires configuration, usually the Time and Date is wrong.
If this occurs every time you boot up your computer and have changed the Date and Time then this could be caused by a flat BIOS battery.
If so, replace the BIOS battery and then configure the Date and Time and you won't get this error again.
May 14, 2011 | Dell INSPIRON 6000 CENTRINO...
Invalid configuration information-please run SETUP program
Here is what you do, go into the BIOS setup, usually you press the DEL key OR F2 or whatever your one is, IT should say on screen as it boots up.... it says "Press YOUR- KEY Key for SETUP". So, get into setup, using your manual ensure it is set correctly. Then SAVE SETTING and exit All should be good now.
Feb 06, 2010 | Dell INSPIRON 6000 CENTRINO...
Dell Ispriron E1505 has a display message, invalid configuration information Please run setup program but won't go into setup. Machine goes to preparing setup menu and then screen goes grey and machine...
Dec 02, 2009 | Dell Inspiron E1505 Notebook
How to know dell 370 precision battery
If the battery is changed, that will mean that the BIOS was set back to january 1 1980.
Go into BIOS, set the clock to the correct time.
For DELL 370 precision , here is the BIOS instruction:
http://support.dell.com/support/edocs/systems/ws370/
Replacing the Battery caution.gif CAUTION: Before you begin any of the procedures in this section, follow the safety instructions located in the Product Information Guide. notice.gif NOTICE: To prevent static damage to components inside your computer, discharge static electricity from your body before you touch any of your computer's electronic components. You can do so by touching an unpainted metal surface on the computer.
A coin-cell battery maintains computer configuration, date, and time information. The battery can last several years.
The battery may need replacing if you have repeatedly reset the time and date information after turning on the computer or if one of the following messages appear:
Time-of-day not set - please run SETUP program
or
Invalid configuration information -
or
Strike the F1 key to continue,
F2 to run the setup utility
To determine whether you need to replace the battery, reenter the time and date in system setup and exit the program to save the information. Turn off your computer and disconnect it from the electrical outlet for a few hours; then reconnect the computer, turn it on, and enter system setup. If the date and time are not correct in system setup, replace the battery.
You can operate your computer without a battery; however, without a battery, the configuration information is erased if the computer is turned off or unplugged from the electrical outlet. In this case, you must enter system setup and reset the configuration options.
Jul 03, 2009 | Dell Precision 360 PC Desktop
Open Questions:
Dell [email protected]^+[1][email protected][email protected] Support Phone Number Tech Support Number Dell Printer Tech Support Number+1(855) 221-4867 time to gayo independently owned and operated all kind of technical support. There are a long series of Dell Printer s including latest technology and affordable price. Dell Printer produce All-In-One with basic printinG copying and scanning functions. Antivirus s are compact and lightweight.Dell Printer Tech Support Number 1(855)221-4867 is an independently owned and operated all kind of technical support. There are a long series of Dell Printer s including latest technology and affordable price. Dell Printer produce All-In-One with basic printinG copying and scanning functions. Antivirus sare compact and lightweight.Dell Printer Tech Support Number 1(855)221-4867 is an independently owned and operated all kind of technical support. There are a long series of Dell Printer s including latest technology and affordable price. Dell Printer produce All-In-One with basic printinG copying and scanning functions. Antivirus s are compact and lightweight. Dell Printer Tech Support Number 1(855)221-4867 is an independently owned and operated all kind of Tech support. There are a long series of Dell Printer s including latest technology and affordable price. Dell Printer produce All-In-One with basic printinG copying and Dell Printer Tech Support Number 1(855)221-4867 is an independently owned and operated all kind of Tech support. There are a long series of Dell Printer s including latest technology and affordable price. Dell Printer produce All-In-One with basic printinG copying and scanning functions. s are compact and lightweight.Dell Printer Tech Support Number 1(855)221-4867 is an independently owned and operated all kind of Tech support. There are a long series of Dell Printer s including latest technology and affordable price. Dell Printer produce All-In-One with basic printinG copying and scanning functions. s are compact and lightweight.anning functions. s are compact and lightweight dell printer configuration web tool dell printer default password dell printer document stuck in queue dell printer drivers dell printer drivers for mac dell printer error 004-321 dell printer error 009-340 dell printer error 016-302 dell printer error 016-302 dell printer error 0502 dell printer error 077-900 dell printer error 1203 dell printer error 900.57 dell printer error codes dell printer filter failed dell printer firmware error 900.00 dell printer firmware error 900.57 dell printer fuser error dell printer goes offline dell printer goes offline windows 7 dell printer goes to sleep mode dell printer green flashing light dell printer grinding noise dell printer installation dell printer jam problem dell printer job stuck in queue dell printer keeps calibrating dell printer keeps going offline dell printer keeps initializing dell printer keeps jamming dell printer keeps printing same document dell printer keeps saying downloading application list dell printer keeps saying left cartridge incorrect dell printer keeps saying offline dell printer keeps saying out of paper dell printer keeps saying paper jam dell printer network setup dell printer not communicating with computer dell printer not printing dell printer not printing black ink dell printer not printing color dell printer not recognizing cartridge dell printer not scanning dell printer not working with windows 7 dell printer not working with windows 8 dell printer not working with windows 8.1 dell printer offline dell printer only prints one page dell printer out of paper error dell printer pc life warning dell printer problems dell printer setup wireless dell printer tech support number dell printer there is a problem with the printhead dell printer troubleshooting dell printer will not print dell printer wireless setup dell printer wireless setup utility dell printer won't print dell printer won't print black
Jul 23, 2019 | Dell Computers & Internet
Dell Inspiron XPS M1710 Notebook Logo
212 people viewed this question
Ekse
Thomas F. Schneider
Joel Rodriguez
Joel Rodriguez
