Here is a link to the manual. The information you need in there.
http://dlcdnet.asus.com/pub/ASUS/mb/sock754/K8V-MX/E2335_K8V-MX_h.pdf
SOURCE: HD LED and POWER LED Connection
here is a link to the manual that should give you a diagram - http://dlsvr03.asus.com/pub/ASUS/mb/sock478/p4bgl-mx/e1339_p4bgl-mx.pdf - hope this solves your problem.
SOURCE: Don't read the HD
Clarification please:
What????
What kind of computer, os, internal or external hd's?
SOURCE: motherboard not starting!
try to set the jumper setting of the cmos battery in *********** board.you set the jumper setting 1 and 2 with in 3 mins.then try to set back the original setting the jumper seting in 2 and 3.
[email protected]
SOURCE: how to plug power switch into ASUS A8N-LA
you have a panel in the left of your ata connetor in motherboard, read there (is writen f_panel1) for apropriate led place (for example reset is writen rst, power led is writen pwr and disk led hd or hdd.)
SOURCE: asus k8v-mx mbd no display
It would be nice if you can get something on the screen, isn't it? Try fixing a AGP VGA and check. Remove HDD cables while checking for MBD errors.
ok you have defective power supply in hotside section! maybe they have abnormal oscillation!
