How do you set the date
1. Close the lens barrier and press the LCD monitor ON/OFF button to turn on the LCD monitor.
2. Press the Menu button to display the Menu.
• See page 37 for how to use the Menu.
3. Press the top/bottom arrows on the Jog dial to select MODE SETUP, then press the right arrow.
4. Select the date order using the top/bottom arrows on the Jog dial. Press the right arrow on the Jog dial to adjust the first setting month/day/year.
5. Press the top/bottom arrows on the Jog dial to adjust the first setting, then press the right arrow on the Jog dial to adjust the second setting.
Repeat until the minute is adjusted.
• 00 will appear for the year 2000.
6. Press the OK button to save the setting. Press again to cancel the Menu.
• For accurate setting, press the OK button when the clock hits
00 seconds.
• If the Menu button is pressed before the OK button, the
setting and Menu mode will be canceled
