Where is it located and where can I get a diagram to find the fuse for the radio
SOURCE: service engine soon light on 2003 Saturn Vue
Here is the definition of the code in GM manual:
P0128 - Coolant Thermostat Below Thermostat Regulating Temperature, this indicates the engine is running cold, u need a thermostat
SOURCE: 2003 Saturn VUE Steering Column Noise and Resistance
i am a saturn tech and ive never heard of this concern,the columns do go bad but they just set a ses light and cut out power,the column could be bad,it could also be the intermediate shaft u joint binding,,,i rec take to dealer, could be serious
SOURCE: 2003 saturn vue trouble code p1599
P1599 IS A STALLING ISSUE COULD BE BAD GAS / BAD FUELPUMP DIRTY FUEL FILTER
DISCONNECT BATTERY AND SEE IF THE LIGHT COMES ON AGAIN
U2107 HAS SOMETHING TO DO WITH THE COMPUTER LOOSING POWER AT THE BODY MOUNTS CHECK CABLES AND GROUND STRAP
SOURCE: where are the spark plugs located on saturn vue
assuming this is a v6 engine, the spark plugs are located under each coil....removal of coil is the way to access the spark plugs
