The display is still working as I can just about see the letters scrolling across when the unit is switched on. However there is no light behind the display panel that can be replaced as far as I can see. Can anyone advise please?
SOURCE: my microwave says "child" and won't play anymore
Not sure of the TT series models but for the NN series models the procedure is as follows:-
If "Child" is displayed in the display window, then the child safety lock is on.
To remove the child safey lock, press the "Stop/Reset" button 3 times in fairly short succession (less than 3 seconds). The time of day or just the Colon sign (:) is then displayed
If you later want to apply the Child safety lock, then, when the time of day (or colon sign) is displayed, press "Start" 3 times (again in short succession).
Hope this helps
Doug
SOURCE: Panasonic NN-P295 Cooktop Light not working
We see (and repair) this
a lot. The problem is on the control panel, which
we regularly repair nationwide by mail for $39.95 postpaid in about a
week.
At
our Web site, you can get details of our service, plus we have a video
available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
This light failure often
occurs when a bulb goes out and the filament
shorts, or when the bulbs are removed or installed without first
unplugging the oven from the power line. Either can cause such a
failure on the controller.
This can often also
affect the exhaust fan operation, too. The lights and fan can be
inoperable or stuck on too.
Feel free to contact me directly (and please remind me of your
full model number) for more information & help.
We're
happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
William E. Miller
[email protected]
http://www.microwavedisplay.com
SOURCE: Replacement light bulb for Panasonic NN-9853 Microwave
Hello, I also have a Panasonic Microwave ( model NN-S 564 or 574 ?) They are very similar.
I have just removed the outer cover 5 screws ( unplug of course ) and have located the bulb holder which is a white plastic component with two clips holding the globe, pull it out and remove the two spade clips connected to the globe. The globe will come away attached to a black plastic mount. Next........do the run around to find someone who sells it.
Perth has an authorized distributer/repairer in Myaree whose details I got from Panasonic. He may sell them. otherwise I will try a couple of specialist light globe suppliers I know....PROLAMPS in Belmont and one in BALCATTA whose name escapes me but I have been there before...Hope this helps others.
Martin
Testimonial: "Hi - and thanks Martin for an excellent description of the process. Perfect assistance for a handyman-challenged guy like me. Thanks Grant"
SOURCE: Door Release Button not working on Panasonic Microwave NN-T664SFT
The problem I had experienced with the Door not opening easily will be resolved by removing the micowave oven top cover with a tamper proof torx head, replacing the door switch and reinstalling the top cover.
