Computers & Internet Logo
A
Anonymous Posted on Jan 30, 2012
1 logical drive offline 4 online drive defunct
1 Related Answer
Anonymous
  • 64 Answers
  • Posted on Oct 13, 2010
SOURCE: ServerRAID-6i Logical drv =1, Others=0
HI, It appears you may have a failed "physical" drive in your Raid set on the server. The system will run fine with one failed drive, but it is recommended to have the drive replaced by it's vendor, or vendor representative. If the 2nd drive in your raid set fails. You will loose your logical drive and all your data on this drive.
You may wish to confirm you have successful, recent backups, just in case another disk fails before your failed drive has been replaced.
tip
How to back up a offline disk folder
<p>Backing up your computer in a folder on the hard disk that goes offline, because sometimes surprisingly simple for the Windows Sync Center. You have a network available offline. Your computer will copy the backup of the hard drive of your computer's hard drive when you're online. The folder will appear as if it were accessible online, because the files are copied to the folder on your computer and then sync when the device is online. <br /> <p><br /> <p>1. Click "Start", "computer" and open the folder with your backup folder. Right-click the backup folder and click on "always available offline." <br /> <p><br /> <p>2. Waiting for the files in the directory so that the copy on your computer available offline. <br /> <p><br /> <p>3. Right-click again on the backup folder and click on "Map Network Drive". Click "Finish". <br /> <p><br /> <p>4. Click Start, Control Panel, System and Security "and" Backup and Restore. "Click" Create Backup.<br /> <p> <br /> <p>5. Select the mapped drive that you defined earlier in the Drive list. Click "Next" and follow the steps to complete your backup to adjust. Click Save Settings and perform the backup. " <br />
on Jun 22, 2011 • Computers & Internet
Ibm bladeCenter -S storage one hdd offline .how to forcely online
It probably is "offline" because it is "dead", and thus cannot go "online".
Replace the disk-drive, and the replacement should go "online", automatically.
ServerRAID-6i Logical drv =1, Others=0 Firmware7.12.13,Status OK Warning:1 Logical drive(s) Offline Warning:1 Online drive(s) defunct
My printer shows "offline". How do I get it online?
Did you recently change the ink cartridges=? Did you use third party or refilled cartridges?
If so, that may be the problem. Some printers have logic in them to drop offline if ink other that the manufacturer's is used.
If you are using factory new ink, please let me know and I/ll continue to try and assist you.
Don
2answers
2answers
Printer displaying paper out on on control panel
You may be able to calibrate the paper out sensor to fix the problem.
Set the printer to Offline.
Press the Enter and Line Feed keys together and hold pressed until the alarm sounds (typically 3 or 4 seconds).
You should have seen briefly displayed, Tech Access On
The display will again say Offline.
Press the Mode Key, display will show Offline Normal.
Press either Arrow key until display shows Offline Test.
Press the Forms/1 key.
Press either Arrow key until display shows Test Diag.
Press the CPI/2 key.
Press either Arrow key until display shows Diag Prnt Cal.
Press the LPI/3 key.
Press either Arrow key until display shows Pap Out.
Press Enter
Follow the instructions on the LCD display, which will advise on removing and reinserting the paper.
After you have compleated the calibration place the pritner ONLINE to exit the menu.
And finally turn the printer power off, wait ten seconds and turn the printer power on again.
If the problem still exits you may need to repalce the lower tractors or the main logic board.
Defunct of HDD in netfinity 7100 RAID
Download IBM ServeRaid , this software will allow you to see whats going on and correct issues
1helpful
Physical drives not found
I"t says one logical drive is offline and two physical drives are defunct."
sounds like RAID. Try booting up off of one drive. If there is no OS, try keeping one drive in the drive bay and see if you get a orange light then. like dereknewland said, could be the backplane.
Defunct drive
You could rebuild the defunct drive with the raid program on your server.
i don't know your type and model of your server.
8488 or 8648 and the model 3 digits.
for this you need serveraid manager
http://www-304.ibm.com/jct01004c/systems/support/supportsite.wss/docdisplay?lndocid=SERV-RAID&brandind=5000008
please do not update your firmware or drivers at this point if applicable.
if rebuild of a defunct drive doesnt work you'll need to change the drive. remember in a raid 5 you need min. 3 drives.
Top IBM Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
