There are multiple ways to update iPad. The easiest way is to do that in the Settings app. Follow below steps to reach the aim.
1. If a pop-up panel tells you that iTouch latest version is available, you can then tap on the button of "Install Now" to begin to update to apple iOS latest version.
2. You can also manually check out if the apple iOS latest version is available now. Now you can follow the steps shown below to have a try.
a) Connect your iPod to good Wi-Fi connection and make sure your iPod storage is enough and the battery is able to support the iPod update.
b) Click on "Settings > General > Software Update" successively.
c) When your iPod has detected an apple iPod latest version, you can click on the button of "Install Now". If a dialog requires you to delete some apps temporarily because the new version needs more storage, you can click on "Continue" to uninstall the apps. If you click on "Cancel" button, your apps will not be uninstalled.
d) After that, iPod will begin downloading and installing the apple iOS latest version in no time. Wait until the update is finished.
The process to update to iTouch latest version is not hard at all. Actually, before the update, you can manage your iPod files to make some room for the new version or to make the process much smoother. The next two parts will instruct you how to manage files via iTunes or iTransfer in detail.
For more methods, check:
How to Update iPod to the Latest iOS Version
Cannot close apps on new version iOS 7
can open the ipad and close it but nothing else works
