Question about Sony XM-2150GSX Car Audio Amplifier
I need a wiring diagram for a Sony xplod 4/3 channel power amplifier xm-554ZR 600W
Am tryngt hook up 3 10 inch pioneer subs
Posted by Seth Dains on
5 Related Answers
informatica
Greg Cann
  • 1114 Answers
SOURCE: Wiring Diagram for Sony car amplifier XM-554ZR
You can download the installation manual from the link below: http://www.sony.co.id/support/product/xm-554zr?site=hp_en_ID_i It has the following diagram plus other hookup info... Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Aug 14, 2007
DrFeelGod
  • 14 Answers
SOURCE: wiring diagrams
Look here: http://server4.nodevice.com/down/3a1657608f40b3f62b18e5416ded9ec7/xm-zr607.pdf
Posted on Dec 07, 2008
Anonymous
  • 5 Answers
SOURCE: my 600w power amp XM-554ZR wont turn on
open it n there is a red wire look at the end of it n u would see a black celinder with a with a white strip on it change that part if it is burn
Posted on Jul 14, 2009
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: How to install Sony Xplod XM-1652Z Car Audio Amplifier
First you will need to post the # of voicecoils each subwoofer has, and their resistance.
Next - you can purchase an amplifier installation kit just about anywhere that will supply you with everything needed to wire up 1 amplifier.
Power wire w/fuse
Ground Wire
Remote Wire
RCA cables
Speaker Wire.
CLICK HERE for your manual.
Thanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
Posted on Jul 24, 2009
Chris Jowsey
  • 208 Answers
SOURCE: Xplod XM-554ZR Car Audio Amplifier: powr/protect light comes on red not green...
Hi, disconnect all speakers from unit and try again - if red light still shows then your amp has died.
If the light goes green, then start testing for shorted speaker/wiring. This includes speaker wiring to vehicle shorts - there should be an o/c reading on your meter
Posted on May 05, 2010
Subs wont turn on
make sure there is correct wattage with the subwoofers and the power supply
Is the sony xplod cdx-gt71w able to support a subwoofer without another amp
Sure is.
The sony is bridgable as follows:
  • 100W x 4 @ 4 Ohm
  • 100W x 2 + 250W x 1 @ at 4 Ohm
  • This will allow 2 channels to run 100 watts each @ 4ohms with an additional single channel with 250 watts @ 4 ohms.
    The single sub channel is created by bridging channels 3 & 4
    My 600w power amp XM-554ZR wont turn on.Its an Xplod 4/3 channel, and it was working fine...until yesterday that i checked it. the green light was off.
    1helpful
    How to put 2 subs on a Sony XM 554ZR bridged
    Unless it is a 4 channel then you will have to run them in series. Keep in mind that you will only have mono sound.
    Bridge a two channel amp
    i the search bar type in....subwoofer wiring diagram....then go to crutchfield and it shows you your options.......
    Car amps
    important is to hav correct wires and groud cable...
    1helpful
    Xplod amp
    You have 3 power connection, +12v goes directly to your vechile's battery (make sure this is fused) REM connects to your head unit which tells the amp when to turn on and off (usually very thin wire, comnpared to the gnd and +12) Te gnd you already know where it goes. Then connect your sub to + and - speaker out put. If you run this bridged it will increase your output, must be 2 channel to bridge to 1 channel or a 4 channel bridged to 2 channels. Hope this helps.
    14helpful
    5answers
    Sony XM-2150GSX Car Audio Amplifier Logo
    Top Sony Car Audio & Video Experts
     Francisco Mauricio...
    xxxxxx xxx
    Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
