Question about RCA F32649 32" TV
G Cable Where can I get a G cable for my TV and is there a way to hook up my Satalite feed, vcr, and dvd without it. Everything I've tried has failed to produce anything but static.
Posted by Roy Bloomer on
5 Related Answers
Anonymous
  • 3130 Answers
SOURCE: RCA ColorTrak 27" (non flat) connection to VCR/DVD combo
To Make the rca type cables to work or the red white and the yellow , you have to change the INPUT from RF or TV to VIDEO. Good Luck
Posted on Jun 25, 2006
tvtek
Duke
  • 1284 Answers
SOURCE: Cannot get DVD to Play on TV
Try the old RCA/GE channels of 90/91 or 92 to get to the inputs. Or try entering channel 00. Let me know if that works.
Posted on Feb 23, 2007
Anonymous
  • 944 Answers
SOURCE: How to hook up a DVD player
Go to this link; http://www.amazon.com/RCA-32-Stereo-TV-F32450/dp/B00006HMDB and a short way down under "Product Details" there is a link to the product manual page 7 and 8 of the manual (page 9 and 10 of the pdf file) should tell you what you need to know. Please post again if you still have trouble; Hope it helps :)
Posted on Mar 29, 2007
Anonymous
SOURCE: strange audio problems
called a tve repair man tha is a buddy of minr hr had me unplug the tv to reset the ic ship and it worked !!! thanx and good luck
Posted on Sep 05, 2007
Anonymous
  • 46 Answers
SOURCE: RCA TV - Trying to hookup new dvd/vcr player to old tv with only antenna input
The input on your television is probably coaxial (for cable or an antenna) which means it needs an RF modulated signal. You can find one of those at your local department or electronics stores. Just look for an "RF Modulator" or "video-RF convertor." They're most commonly used to hook video games up to older televisions.
Now, if you've got an old VCR handy, that has an external input, it already has the RF modulator built-in.
Posted on Nov 08, 2007
INSTRUCTIONS FOR (EMERSON DVD/VCR) MODEL EWD2004
it sounds that your tv has no audio/video input jack so you don't have place to insert the rca cable. what you need is an RF converter where you can hooked up the 3 cable wire for audio( L/R), video.then the other end you need to use an RF plug with wire that you can plug into the RF tuner of the tv and the other end to the RF converter.hope this can helped thanks for using the fixya.
Aug 12, 2012 | Televison & Video
I have free cable at where I live now and hooked up my tv to the cable but now I don't know how to hook up my vcr player and my dvd player to my tv so I can tape my soap opera & watch dvd's. ...
What tv do you have? Whant model? DVD player and VCR can hook up to your tv in many different ways via HDMI, S-video, Component and Audio/Video cable.
May 07, 2011 | Televison & Video
Sharpe lc32sb27u & DVD and everything is pink
test dvd on another tv, or change the cable,this is probably some electrical problems on lcd output connector, or the cable defective
Nov 28, 2009 | Sharp LC32SB27U LCD TV
Digital converter
If you recieve your signal on this TV over the Air (Rabbit Ears) then Yes you will need a digital Converter for this TV. If you are hooked up to Cable or a Satalite Dish, your TV will continue to work without the converter box.
Dec 29, 2008 | Emerson EWC27T3 27 in. TV/VCR/DVD Combo
Cable/ant. hook-up
If you have a yellow/white jack on your DVD/VCR unit you can connect it to the TV using composite cables. If you only have the coax output on the DVD player you can buy an RF modulator that will convert the coax to composite also. But if you have two ports on thhe DVD player as most combos do the top is usually an input source such as cable and the bottom is the output that goes to the back of the tv. You could also buy a "splitter" and attach the cable and dvd coaxs to each of the out ports(they will be side by side) and on the opposite end, which is the in run a coax from that port to the tv coax port.
I hope this helps you out. If you need assistance you can visit me on the chat portion of this website.
Sep 09, 2008 | Philips Magnavox DVD/VCR Dual Player
Vcr hook up
Have you tried to run:
Coax from the wall to your cable box.
Coax from the cable box out to the VCR cable in.
Coax from the VCR cable out to your TV?
What connections does your TV have? RCA or coax?
Mar 21, 2008 | Sharp DV-RW340U DVD Recorder/VCR
Can't hook up DVD player
I have a cable box and a Samsung DVD-V5500 player. How do I hook up the 3-part cable to the back of the player?
Jan 12, 2008 | Protron PD-007 DVD Player
At the end of my wires
If you use scart cables you almost cannot go wrong. You can either hook one scart from your DVD/VCR to the TV and one from the cable box to the TV, and switch using the A/V button on your TV.
Alternatively, you can hook one from your cable box to the "in-port" on your DVD/VCR, and one from the DVD/VCR to the TV. In this case you should be able to record programs from your tuner.
Dec 11, 2007 | Toshiba 27A44 27" TV
How do i connect to my tv?
the yellow line is for the video the red and white is for the audio, and you can connect your DVD to your TV.
Oct 02, 2007 | Coby DVD-207 Portable DVD Player
RCA F32649 32" TV Logo
64 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
