Question about Pitney Bowes Office Equipment & Supplies
SOURCE: Service Manual
A good place to find one is on copytechnet.com. I checked some of the service manual websites and nothing was comming up with that model number. It could be because Pitney Bowes spun it off into Imagistics and now it's called Oce. Usually the copiers are made by Ricoh. Someone on there would know where to get the service manual under the Ricoh model number as well.
Posted on Jul 11, 2008
SOURCE: Pitney Bowes Copier - C180 - Error E3
The C180 was made by Panasonic and is no way comparable to Toshiba. The E3 code should flash with another code (01, 03, 11,... etc) This other code is required to diagnose problem and is a service issue. If it is an E3 10 or E3 11 there is a corona wire dirty or broken, these are the most common E3 codes. I'm not sure about other codes, you may have more luck looking for info on the Panasonic 7718 just remember to refence both parts of the code
Posted on Sep 17, 2008
SOURCE: I am looking for a service manual for a Pitney Bowes FD40
http://www.pitneybowestsg.com/public/Opguides/Fd40u036.pdf
Posted on Mar 20, 2009
SOURCE: looking for a service/repair manual
At minimum, the drum and cleaning blade need replacing - possibly developer as well. I'm sure the optics are dirty, as well as the charge and transfer corona.
Posted on May 01, 2009
SOURCE: Pitney Bowes Model 9016 Error code E3 01
E3-01 is the toner bottle rotation. for some reason it is not rotating. Take out the toner bottle and be sure it is in coreectly, that the labels are not loose and preventing it from turning.
Posted on Feb 24, 2010
Mar 09, 2011 | Pitney Bowes Office Equipment & Supplies
Mar 06, 2011 | Pitney Bowes 9920 Plain Paper Fax
Oct 01, 2010 | Pitney Bowes AddressRight DA300 Printer
Sep 16, 2010 | Pitney Bowes Office Equipment & Supplies
Jul 24, 2010 | Pitney Bowes AddressRight DA300 Printer
Jan 22, 2010 | Pitney Bowes Office Equipment & Supplies
Oct 30, 2009 | Pitney Bowes C180 Copier
Jun 01, 2009 | Pitney Bowes 9920 Plain Paper Fax
Apr 03, 2009 | Pitney Bowes AddressRight DA300 Printer
42 people viewed this question
