Here are somethings to try,
1. change the needle--flat side goes to the back of the machine
2. check the tension see if it's too tight,,usually 4 to 5 is good
3. rethread the machine top thread & bobbin area
4. check to see if there are any burrs on the needle plate where the feed dogs are (teeth area)
5. you said that you made a comforter for your husband using thick fabric,,some sewing machine are not good at sewing comforters & other heavy fabric,, it's possible that the machine is out of time, which means it will not sew good & mess up,, which means it needs to be serviced by a repair shop technican to see if it is out of time.
