SOURCE: Sony VAIO PCV-W700G Desktop PC
My vaio deshtop cant boot from cd, no boot screen i do not know how to go to bios, i try to press "del", "F9, 10, 11, 12." still cant help. Another problem it cant give sound, window sound was disable.
Please help me at [email protected]
SOURCE: CD/DVD ENCLOSURE in Sony Vaio PCV RX860
http://esupport.sony.com/US/perl/tutorial-display.pl?tut_id=269&mdl=PCVRX860
this link is a tutorial of how to get the side panel off,
to get the cd drive out, you need to do a couple more steps.
first, you will need to take off the top and other side panels. this can be done by looking at the top back of the case. there are two clips that hold the top panel on. push up on the two clips and the top part will slide back and you can pull up on the panel and it should come off.
Next, you should be able to push some more clips on the top to get the side panel off. it should fold down just like the first side.
then, you need to take off the front two panels. the bottom part should be just a couple clips on the inside front of the case, and the top clips will be revealed when you take off the bottom part.
after that is done, you should be able to unscrew the cd/dvd drive from the case and unplug the cables connected to it from the top where you removed the top panel.
then you should be done
SOURCE: Sony vaio cpu is makes a lot of noise
I actually have the very same computer, PCV-RS720G, the best solution is to just upgrade the fan. The easiest thing to do is to take the fan out of the Vaio and bring it with you to Microcenter or whatever your local equivalent is and ask someone in the store for a compatable fan. Unless you feel comfortable ordering on line. I would suggest something with 3 speeds and 9 blades. Silicone pegs (instead of screws) would be a big plus.
SOURCE: sony vaio pcv-rs510 fails to fully boot
reinstall os.bios should be preset to boot from cd/dvd but if not power on then press delete key or escape key till bios loads-in boot opt. select cd/dvd drive first boot.put os disk in drive and restart when asked to press key to boot from cd do so.follow inst. instructions.after insall detects previous version of xp select repair (r key) and follow inst. should solve startup problem without losing data.if not reinstall os but select leave files intact instead of format or you will lose all files.
SOURCE: how to open sony vaio-pcv-w101/w to replace bad ram?
Try this:
STEP 11
Lift up and remove notebook display panel.
STEP 12
Remove hard drive cover, memory cover and modem cover from the bottom of the notebook. Each cover is secured by one screw.
STEP 13
Here’s how you can remove the hard drive. Remove four screws securing the hard drive caddy to the base assembly. Slide the hard drive down to disconnect it from the motherboard. Lift up and remove the hard drive.
STEP 14
Removing memory modules (if needed). Carefully spread latches on both sides of the memory slot. The memory module will pop up at 30 degree angle. Pull the memory module from the slot by the edges.
Removing modem card (if needed). Remove two screws securing the modem card. Lift up the modem card to disconnect it from the motherboard and unplug cable from the side.
Hope this Helps
DR GEEK MD
