Canon EOS 40D Digital Camera Logo
Question about Canon EOS 40D Digital Camera
Canon eos d40 makes a long noise before it takes a picture
  • Anonymous Jan 29, 2012
    Makes several beeping noises for several seconds, then takes the picture.
Sean Kelly
  • 37 Answers
It sounds as though you have activated one of the timers. On the LCD display on top of the camera look in the bottom right-hand corner of the display and see if there is a symbol that looks a bit like a one-handed clock (the timer symbol). If so, press the AF-Drive button on top of the camera and rotate the large, circular selector dial on the back of the camera until that symbol goes away. Now the camera should shoot normally.
Posted on Feb 05, 2012
5 Related Answers
Anonymous
  • 2985 Answers
SOURCE: is my canon eos 400d broken?
This is a Digital SLR With SLR cameras you can only use the viewfinder because the image comesi nto the lens and up to the viewfinder via a mirror. When to take a pic the mirror flips up[usually with a crash] and the image goes to the CCD- afterwards you will get an image briefly in the LCD.
Posted on Sep 20, 2007
Anonymous
SOURCE: Canon Rebel EOS camera
Err 99 is a general error msg. That is, it has to be connected to the service soft that only Canon self or an ASF has, to know more precisely the problem.
To narrow the possibilities;
-choose Av, shutter priority,
-choose the smallest aperture your lens allows, 22 or 29 or so,
-while pressing and releasing the depth-of-field preview button, (front, under the lens release) look into the lens from the front.
If the diaphragm doesn't move it has to be changed. If you have the 17-55 standard lens; throw it away and buy a better one instead of paying a repair. You'd be better off.
If you have the Err msg with several different lenses the problem is in the body itself, often the shutter. Check also your PINs in the CF-slot. If one PIN is toching another; break off the bent one and normally you can go on, the PINs are almost all doubled.
Posted on Aug 05, 2008
Anonymous
  • 11967 Answers
SOURCE: auto focus blocked Canon Eos 1000D
Try cleaning the contacts on the lens and body where they meet with a cotton swab lightly dampened with rubbing alcohol.
Posted on Mar 22, 2010
Anonymous
  • 2335 Answers
SOURCE: Canon EOS - no data on LCD and viewfinder says busy
I can help you fix the BUSY Error or Error 99 of your Canon EOS Rebel XS.
Installation of this Canon EOS Rebel XS firmware version 1.06 update will solve these problems:
  1. Some cameras may exhibit a phenomenon in which the LCD monitor does not display, the shutter does not release, and the BUSY indication remains lit in the viewfinder.
  2. The message, "Err 99 Shooting is not possible. Turn the power switch to<OFF> and <ON> again or re-install the battery", appears on the camera's LCD monitor, and after the above operation is carried out,the LCD monitor displays in a language that is different from the actual language setting.
See the firmware instructions and download the firmware upgrade by following these Fixya Tips :
  1. Follow this link to download a pdf version of the firmware installation instruction guide.
  2. Follow this link to download the Windows Version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  3. Follow this link to download the MAC version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  4. Follow this link to download the Canon EOS Rebel XS / Canon EOS 1000D Instruction Manual.
I hope that helps.
Posted on Apr 15, 2010
Anonymous
when i get on auto focusthe camera doesnot work
Posted on Dec 14, 2010
When I press on the shutter button there is a whirling noise and the camera will not take a picture.
Have you tried cleaning the contacts on the lens/camera?
Is the lens free from obstructions?
A whirling noise when trying to take a picture and it won't focus or take a picture.
the sound you hear is the camera trying to focus, it sounds like it could be ready to give up.
1helpful
When i am taking picture in bulb,camera is taking to long,sometimes 3-4min, to show picture on LCD after shooting.It's brand new camera canon 550d. My canon 500d, what i used to have before, never had this...
This is normal behavior for taking a picture using the bulb. After you release the bulb, the camera may detect that a noise reduction step is necessary. The noise reduction process can take as long as the exposure time. There is an option to disable long exposure noise reduction. Click here to see the manual for details.
1helpful
How to use the monitor as a view finder on nikon d40
The Nikon D40 works as SLRs have worked for half a century, providing a viewfinder for composition and framing. The monitor in the back is for menu settings, shooting parameters, and picture review. Only more recent dSLRs (in Nikon's case, starting with the D3 and D300) provide the LiveView capability.
2answers
The display does not come on, there is a "busy" sign flashing
Sounds like the problem Canon had to fix for me with my S2 IS which did the same thing. My camera shot blank pics. It turned out to be a stuck shutter. The camera makes all the usual noises, but the shutter is stuck closed.
170-500 apo nikon for nikon D40
it will mount fine, but I don't believe you will have autofocus.
Canon eos rebel xsi making buzzing noise and not fucussing ???
may be lens VR is weak please dont keep cell phone near camera
Canon eos 400d
Contact Canon - some makes of lens which are not Canon are not electronically compatible for various reasons, and can actually damage the camera. So, get using the phone and check if it is compatible before doing anything else - but personally, I would not use the lens until I find out
Canon 350d
No, the so called 'live view' ( seeing pictures in real time on your LCD monitor ) is available only on the latest models that are coming out now ( Canon D40 and Nikon D3 and D300 have this feature ).
Canon EOS Rebel G
From the Canon Help Email - this worked for me: If you are using an EF series Canon lens, please remove the lens and clean the lens contacts with a pencil eraser. We also suggest that you remove the film and battery for 15 minutes; ensure that the battery has a full charge and reinstall. If the issue persists, we suggest testing the camera with a different EF series Canon lens. Should this persist with a different lens, then the camera body itself will need to be examined.
Top Canon Cameras Experts
old marine
old marine
David Shaub
shadow
Are you a Canon Camera Expert? Answer questions, earn points and help others
