Press the "Eject" button on the PlayStation 3 console and hold it for at least 10 seconds; if your PS3 has the "force eject" feature included it will eject the disc regardless of whether the console is frozen or not. Turn off the console and turn it back on before inserting new discs. Unplug the power cord and any other cords from the PS3 console if the "force eject" feature does not work and you own a PS3 Slim. Turn the console upside down so that you have access to the bottom of the console. Locate the small compartment door on the bottom of the console. Remove the door by pulling it up and off the console; a blue screw and a small hole should be visible inside the compartment. Insert a Phillips-head screwdriver into the hole. Turn the screwdriver in a counterclockwise direction to manually eject the disc. Once the disc is removed, replace the compartment door and turn the PS3 console back to its correct position before reconnecting the power cable and any other cables you previously removed.
ou have the infamous YLOD, aka. Yellow
Light of Death. This is the number 1 cause of pS3's dying. It is an
overheating issue linked to your CPU and GPU (the processor chips)
You will need to find a local PS3 repair shop who can repair this. Do
not try to attempt repairs seen on the internet yourself as some
would suggest.You could make things much worse and render the unit
totally unresponsive. The repair process takes about 3 hours.
IT CAN BE FIXED*
FOR THE DISC THAT'S STUCK INSIDE?
If you have a unit that is not
backwards compatible, any non 60g or 80g then you can retrieve your
disc.
Power off the unit using the toggle switch on the back. Hold down the 'eject' button and turn the toggle switch back from off to on. This will run a fan test and eject your disc. Remember, this will only work on the 20, 40g models. Not the backwards compatible units with the 4 usb port holes and the memory card slots.
Does the lights blink red? If so, You
have the infamous YLOD, aka. Yellow Light of Death. This is the
number 1 cause of pS3's dying. It is an overheating issue linked to
your CPU and GPU (the processor chips) You will need to find a local
PS3 repair shop who can repair this. Do not try to attempt repairs
seen on the internet yourself as some would suggest.You could make
things much worse and render the unit totally unresponsive. The
IT CAN BE FIXED*
disc.
You have the infamous YLOD, aka. Yellow
IT CAN BE FIXED*
disc.
IT CAN BE FIXED*
FOR THE DISC THAT IS STUCK INSIDE?
disc.
card slots.
not try to attempt repairs seen on the internet yourself. You could
make things much worse and render the unit totally unresponsive. The
IT CAN BE FIXED
IS THERE A DISC STUCK INSIDE?
disc.
Does the lights blink red? If so, you
processor chips) You will need to find a local PS3
try to attempt repairs seen on the internet yourself. You could make
can retrieve your disc.
