I installed a Leviton TTI06-1 touch dimmer switch in place of an old rotary dimmer switch. Single pole application, black-to-black, blue-to-white, green-to-ground, yellow terminated with a wire nut. The green indicator light comes on, but I can't get the actual light that the switch controls to turn on. The switch is obviously hot (indicator light is on and voltage detector registers the current), but there's no power going to the light fixture (I changed nothing there). Any suggestions?
SOURCE: Need help hooking up a single pole Leviton dimmer switch
hook up the red to red
black to black
green to bare wire
tie white wire to other whites in back of switch box in the wall.
If no whites in there cap it off with a wire connector.
SOURCE: Single Pole Dimmer Installation
I'm not sure if this is going to work in your case, but I'm pretty sure it will...
Green to ground (probably bare)
Black to black
White to the red that's not labeled 3-way
wire nut on the red labeled 3-way
That should fixya!
SOURCE: Have a Leviton dimmer with red, black and green
You are correct in assuming green is the ground and connects to bare copper wire. Black is always the HOT wire and should be attached to the black wire. Red wire connects to white wire.
