I changed my DVD location on my tv inputs, how do I re program my remote?
When I hit DVD on my Osiris remote it goes to hdmi 2. I changed my DVD to a different location on my tv (video 2). How do I program my remote so the DVD button will go to video 2?
Assuming the DVD player has an HDMI port, run an HDMI cable from the DVD player to an available HDMI port on the TV. Let's say you have your TV service going to HDMI #1 on the TV, you can run the DVD to HDMI #2. When you want to watch a DVD, you must select the input/source on the TV remote to change it to HDMI 2(or whichever port you used). When ready to watch TV again, use the same button to change back to HDMI 1 (or whichever HDMI port you used for TV service). If you do not have an HDMI port on the DVD player, then you must use whatever type of connection it has and connect to the corresponding port(s) on your tv, Then follow same directions as above regarding choosing the input/source on the TV remote.
Liz,, most DVD players come with RED, Yellow, White cables. on back of ur DVD player find the holes with the matching colors. and insert cables, now go to ur TV , on the back you should see some of the same colors plugins ,.once u have done that . put in a DVD and hit play. now go to the input/source button on ur TV or remote and push it . u might see a drop down menu if u do highlight the AV or Video 1 or 2 or 3 till u get a picture. when finished u will have to hit the input button and go Back to where u were in order to watch what u had it on before. NOW if u have a Blu Ray DVD player all u need is the HDMI cable , find the HDMI output onback of player and on the TV find the same. your tv might have 3 or so HDMI inputs ,, any will work. as before put in a movie, use ur remote , input button and find the HDMI on the menu and high light it. .
Sounds like the input board on the tv fried. (45-65$ fix if that's it)
Try the same two devices on different inputs , ie change from hdmi to component , or just use hdmi 2 instead of one, you get the idea.
Make sure the devices dont work on other inputs on the tv.
Then take a different device , like a 3rd dvd player and try it.
If nothing works in that input but works in other inputs the tv input board might (likely) need replacing.
If the third fresh device does work in that input , it is both dvd players or the cable you are using. (try to use a different cable in the tests than the one you have already used. )
This sounds like a basic setup, so correct me if I made any wrong assumptions.
You have 2 "output" devices: a Roku and a cable box. Both have HDMI outputs.
You have 1 "input" device (your TV) that has 2 HDMI inputs available.
So, you need one HDMI cable to connect your cable box to your TV. Remember what HDMI port it's connected to - the back of your TV probably says "HDMI 1" and "HDMI 2" or similar. That's the "input name" of your TV.
Connect your Roku to your TV with another HDMI cable.
Now turn on your TV and use the remote to change between the inputs. Most remotes have a button that says INPUT or SOURCE (or sometimes a dumb little icon with no writing). If you press that it should change inputs. Usually, each time you push the button will cycle to the next input, so sometimes you have to hit it a bunch of times until the on screen menu shows the input you want. Most TVs will automatically switch to the selected input after a few seconds, so you don't have to push any buttons on the remote to tell the TV to change inputs.
If "at the same time", you meant actually watching both Roku movies and your cable at the same time, you are talking about a TV feature usually called "picture in picture". That should be possible, but will depend very much on your TV. I'd suggest checking your TV manual, or calling the company's 1-800 number and asking them to talk you through it.
newer tvs need to know that HDMI is attached to give you signal also need to turn on device from where HDMI signal comes from.post the model of your tv ,or if universal remote has input try this,1.- connect hdmi ,2.- turn on device(dvd,ps3,blue ray, etc.) 3.- press input on remote ,or go to menu manually on tv and find input.hope it works.
You either need to change the input source. Currently the source is TV, depending on how you connected the DVD player to the TV, it should be composite (A/V), component video or HDMI. (S-video is also a possibility. Very few DVD players are connected on the RF (coax) input which might be channel 3 or 4 without having a converter between the DVD player and the TV.)
Look on your TV remote for a button marked Source or Input. You may also find this button on the TV. (On some TVs, this may also be accessed through the menus.)
How did you connect the TV and the DVD player? If your audio and video were connected via three RCA plugs (yellow, red, white) on each end, then use the composite video input. If you used cables with 3 RCA plugs for video (yellow, green, blue) and 2 for audio (red/white), then switch to the component input. If you used HDMI which carries audio and video in one cable (with rectangular ends), then use the HDMI input.
Some older TVs only have the Source/Input button on their original remote. Not all universal replacement remotes have this button, you may need a different remote. Those that do may require you to try additional codes for your TV manufacturer to enable the button. (The on./off buttons often will work with more of the codes for a brand.) The ones that can be programmed via a USB connection to a computer are most likely to support the function. Please add a comment with the type of TV for additional help with this.
Not sure what you mean. The TV comes on and is always showing the DVD instead of TV channels? If that is the case, you need to change the TV input from what the DVD player is using. (for example component or Video 1, or HDMI 1 to whatever the TV is using for television provider's input. (for example HDMI 1 or HDMI 2 or component, or video 1, or video 2.) Usually the remote will have a button that says "input". If you push it, it will scroll through the various inputs. You may need to wait a few seconds between each choice for the change to happen.)
You can look at the cable from your DVD player to the TV and see if the inputs on the TV are labeled, and also look at the cable into the TV from the television provider (comcast, dishnetwork, or TV antenna) to see what input that is as well.
Hi:
Using remote locate a button called tv/video or Input, turn on the DVD player and hit this button until you see your DVD player Logo. Most dvd players use either video 1 or 2, or componet or HDMI outputs. Seems you have changed the TV's input back to TV mode and you need to change it to a video mode input.
You probably need to change the incoming input signal on your tv.
In other words, your audio is coming directly out from your dvd player, and going directly to the audio power amp.
Your video does the same thing, except it goes to your tv. Your tv has multiple places for "incoming" signals to hook in to it. Take a look at where you're hooking your video in - the input should be marked ... something like "Component 1" "Component 2" "HDMI 1" "HDMI 2" ... something like that.
On your remove, there will be a button that says, "Input." When you push this, you will see that your TV brings up an input selection window. Pressing the "input" button on your remote should scroll through the ports on the tv. Briefly pause on each input selection to see if it begins receiving a video signal from your DVD player.
