SOURCE: HP 1020 Issue
Pls check the fusing assembly,something might be stuck or the flag of paper jam sensor might be broken or could have come off.
Happy printing
OMNIPRESENT
SOURCE: False Paper Jam Error
Make sure the paper tray guides are set against the paper more likely to be the back guide not pushing the paper to the front of the tray. If you have the guides set correctly then place one sheet of paper in the tray and blot some methylated spirits on the leading edge along the page width and close the tray and try printing something.
You will have a jam repeat process 3 or 4 times then open tray and remove paper. Where you soaked the spirits into the paper there should be a grubby mark where the feed roller has rubbed and cleaned. Wipe the tray dry and put fresh paper in then hopefully you will now be able to print. If you cannot then the likely thing is that the paper feed pickup spindle is broken and will need replacing.
Hope this helps you and please rate me
Thanks J
SOURCE: paper feed problems hp PSC 1510
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
SOURCE: HP deskjet F380 - 'status: paper jam'. There is no paper jam!
Unplug the power cord and while doing that make sure printer is powered on i mean do not turn off the printer using the power button. When you unplug the power cord than press and hold the power button for 30 seconds. Than release the power button and connect the power cord and then try to print.
SOURCE: My HP K550 officejet printer has recently been
it seems that you are correct
Push the button on either side of the rear access panel or the duplex unit and remove the
panel or unit.
Check inside the printer to make sure that the cam drawer is in the
correct position, toward the front. If the cam drawer is not forward,
pull the cam drawer into the correct position.
With all of the paper trays removed, check to ensure that the pick-up
roller is up, not protruding down towards the tray, and no media is
stuck to the roller.
Remove the printheads and check underneath the carriage and under the printheads themselves. Remove any jammed media.
