Protron PD-758LP Logo
A
Anonymous Posted on Jan 29, 2012
BPD-H758 BATTERY PACK - Protron PD-758LP
1 Related Answer
Anonymous
  • Posted on Feb 20, 2011
SOURCE: need to replace battery or obtain battery charger
i have one ill sell you for cheap if you can pay via paypal we are both safe i can ship it tommorow eric 253-861-7874 [email protected] $40 shipped?
Where can I find a new dpb135 for my LG? It's for a DVD player
I am going round in circles on you query because of the model number, it really needs to be as written by the company 'LG BPD-135', but the results are not coming up as I would have expected. Try one of the battery buyer websites. You may get better results using the model number on the battery itself. Many are available for LG on eBay
https://www.ebay.com/b/LG-Li-Ion-Rechargeable-Batteries/48619/bn_73545930
https://www.google.com/search?safe=off&rlz=1C1QJDB_enCA643CA644&sxsrf=ALeKk00Oixq-dcQdkRGa1-13Z8WqF9UZCw%3A1614969721854&ei=eXtCYJK2M83k5NoP7vS9uA8&q=LG+dpb135+dvd+battery+pack+replacement
Mar 05, 2021 • Cell Phones
How do I fix Service Engine Error 181.514. INK Sense BPD Prine Error.
Have you removed the plastic covering the ink jets on a new cartridge?
1helpful
Sony instructions
Visit the Sony website. They should have a free PDF of the instructions.
How to connect a sony blue ray disc Dvd player model BPD-s470 to my Sanyo Dp32647 32in TV.
Hi Definition Sources (your Blue Ray Disk Player) and Hi Definition Display device (your LCD TV) interconnect to each other using HDMI cable. You can buy them in your local Electronics store or online at desired lenght.
1helpful
Need to replace battery or obtain battery charger for BPD-H758
Need to replace oil pan
If yo ucan see all the bolts on the bottom of the pan, it will be as easy as changing your oil. Make sure you get a torque wrench for the install though so you don't strip the bolts out, and just follow the directions with the gasket.
Fig. 1: Exploded view of the oil pan and related components for the 1990-94 1.6L engine-2.2L engine is similar
Fig. 2: Exploded view of the oil pan and related components for the 1.8L engine
Make sure all old sealer is removed from the bolts prior to installation. Installing a bolt coated with old sealer could result in cracking of the bolt holes.
  1. On 1990-94 323 1.6L (B6E) and 1994 Protege 1.8L (BPD) engines, install the integrated stiffener to the engine block and transaxle. Tighten the bolts to 38 ft. lbs. (52 Nm).
  2. 1990-94 Protege 1.8L (BPE) and 1994 MX3 1.8L (BPD) engines, install the transverse member. Tighten the bolts to 93 ft. lbs. (1 Nm).
  3. Install the front exhaust pipe bracket, if equipped. Install the front exhaust pipe, using new gaskets. Tighten the exhaust manifold flange nuts to 34 ft. lbs. (46 Nm).
  4. Install the oil pan drain plug using a new gasket. Tighten the drain plug to 30 ft. lbs. (41 Nm).
  5. Install the engine undercover and lower the vehicle.
  6. Fill the engine with the proper type and quantity of oil.
  7. Connect the negative battery cable. Start the engine and bring to normal operating temperature. Check for leaks.
Hope helped with this (remember rated this help). Good luck.
Check engine light
oil pressure too low...it must remain above 23.2 psi for the multi displacement system to work...it could be any thing from low or incorrect oil to a powertrain controller..you may need the dealerships help
Top Protron Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
