Go to fw webb and buy 6 inch takeoff .These are galvanized 6 inch steel so you stick it unto the opening then connect your flex duct to it
Posted on Feb 16, 2018
Not sure but i think the link below will help you a lot http://www.bonaire.com.au/-/bonaire/lib/images/pdfs/owners%20manuals/Bonaire-Evaporative-Manual-Control-2002.pdf
SOURCE: My bonaire vulcan ducted heating
Does the green power switch light when the Start
key is pressed?
No: - Is door completely closed? Door switch may
be interrupting power.
Yes:- Check the fuses on the controller PCB
- Check heating element plates for continuity
Hope that helps.........
Posted on Jul 08, 2008
SOURCE: Vulcan-Bonaire : summer breeze
This unit is a cooling unit only. I don't know what switch you are looking at but I don't think it's for the evap. cooler(swamp cooler). I am in the Phoenix, Arizona area and it's very common to have a evap. cooler and a seperate heat/cool system as on the hottest days the evap. cooler doesn't cool enough. I hope this helps. Please give me a positive rating. Thank you.
Posted on Jan 29, 2009
SOURCE: VULCAN BONAIRE Users manual.
Try here http://www.bonaire.com.au/support/documentation/owner/default.aspx
Posted on Jan 05, 2010
SOURCE: Our Bonaire Evap Cooler stopped after power failure
Turn the power of to both the heater and the cooler. Turn the power back on to the heater and the cooler at the same time then reset codes on controller.
Posted on Feb 09, 2010
May 10, 2014 | Heating & Cooling
May 09, 2014 | Heating & Cooling
Jan 29, 2014 | Heating & Cooling
Apr 22, 2011 | Heating & Cooling
Dec 31, 2009 | Heating & Cooling
Sep 08, 2009 | Heating & Cooling
Jan 27, 2009 | Mastercool 67471 Evaporative Cooler Air...
114 people viewed this question
