Kodak EasyShare EX1011 Digital Picture Frame Logo
charles deur Posted on Jan 28, 2012
Siren digital foto frame - Kodak EasyShare EX1011 Digital Picture Frame
Siren digital photo frame manual
Please mention if the fault is related to full failure of the display in which case the power supply or the display section is faulty, failure of the back up inverter circuit cannot be ruled out and in all these cases you need to open the unit to test and confirm.
Nov 30, 2011 • Cameras
COMO CARGAR A LA MEMORIA INTERIOR LAS FOTOS DE UNA TARGETA MI MODELO DE DIGITAL PHOTO ES 7INCH DIGITAL PHOTO FRAME MODEL NO : ZA-DP7OOO RUEGO ME ENVIEN LA CONTESTACION A MI CORREO [email protected] sin...
hola, la memoria interna es menor seguramente en capacidad que la tarjeta ,debes leer en el manual de usuario como hacerlo.
Tambien en configuracion en el modo play buscar la opcion si esta disponible.
Saludos
Feb 28, 2011 • Cameras
1helpful
Dark screen
have you prove to pic fotos. if the camera make fotos,and memorize on the card, but you cant see the foto in the camera schreen this is only a lcd defekt, you must prove if the lcd flat is right connected. if the camera dont pics foto, the problem is in the ccd. you must change the ccd. allor. memorize fotos and you can see trhe foto on your pc...lcd problem contact failure ore lcd faul to change. if the camera dont pics foto...ccd failure to change the ccd.
Blurred fotos
Turn off the Macro shots feature. and your shots will be fine.
2helpful
Siren digital picture frame wont turn on
I had to fix my boss's digital photo frame today and it looks like it was a power supply issue. All i did to fix it was connect a usb cable AND the powersupply. The frame turned on right away. The power supply may not be able to output enough juice for powering up the frame.
Mi mini frame llavero no trajo el software
Can you please translate it in english so i can help you.
Feel free to ask..
Digital Photo Converter
al introducir una foto en la bandeja, en la pantalla se ven muchas
lineas, como si la foto estuviera en movimiento.
Tengo un convertidor digital Vupoint.
gracias, marilú
Uploading pictures from my computer to the camera.
eu preciso do driver pra poder baixar minhas fotos.
atenciosamente,
Danielle
Top Kodak Photography Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
vince
Are you a Kodak Photography Expert? Answer questions, earn points and help others
