Question about Archos Audio Players & Recorders
Does not play the music file loaded
I have sycd my music file to the new archos I have just purchased and they appear in the files but dont play, when I plug the archos to my computer I vcan play the in windows media and if I un-plug it when playing the music stops. I presume the music must be in the archos player. I have 2 other archos units and I sync them just the same and they play.
Posted by robin dinsdale on
5 Related Answers
mstr2kx
Mohammad Abumuailek
  • 102 Answers
SOURCE: GPX MW3337 sync problem
1- Check that your MP3 Player's File system is OK, you can do that using the DOS command (chkdsk /f). 2- Re-install your Windows Media Player 11. 3- Don't forget to update your system, too.
Posted on May 30, 2007
Anonymous
SOURCE: Firmware upgrade results in arclibrary boot failure
I managed to overcome the problem by doing a factory reset. Unfortunately doing this initially created more problems in that on reboot the main screen appearance looked as it should but was almost inoperable. When the usb cable was connected to my pc the disc did appear on My Computer . The system folder was only 1MB. By good fortune I had copied and saved my Archos files before I carried out the factory reset. Copying the original system files ( about 20MB) back to my Archos returned normal behaviour. Further, two additional buttons appeared. One was a manual arclibrary update button and the other a USB setup button . I cannot get file transfer to operate under windows media player mode and Windows media player 11. No problem though. I use PC hard drive mode and carry out a manual arclibrary update. None of this was possible prior to the factory reset. I believe I would still be having serious problems had I not saved and restored my system files
Posted on Feb 11, 2008
Anonymous
SOURCE: When I sync files to My mp3 player, it says "no file" when I diconnect.
I unchecked in the advanced sync setting the box to have windows media player create the drive hierarchy. Then I deleted all files on the player and did the sync again. This time only the mp3 files get written.
Posted on Mar 24, 2008
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
SOURCE: My Phillips Go Gear 8GB MP3 player wont sync music
Windows Media Player 11 ruins this player. Uninstall Windows Media Player 11, and roll back to Windows Media Player 10. Then use version 10 to sync songs to your device.
Posted on Sep 20, 2008
Anonymous
SOURCE: Archos 605 doesn't recognize my music files
from another forum on this site
Thanks and credit to eyez12 - the 2nd option below worked for me
try going to menu, settings, system, and then clicking the update ARCLibrary button, that was all it took for me.
if that doesn't work then go to repair and formatting tools and click "clear temp system files and cache"
Posted on Jan 16, 2009
The music i loaded unto the archos mp3 player is not playing even though i can see the name of the songs
are you sure the files are in a format that is playable by the archos media player? what model is it, and what is the file extension of the music files
Jun 18, 2011 | Archos Audio Players & Recorders
How do I play .wmv on my archos 70?
Following the instructions on this site you should be able to convert your .wmv files to ones that will play on the Archos. http://www.riverpast.com/en/support/tutorials/convert/wmv/archos_video.php
Feb 28, 2011 | Computers & Internet
Hi My wife and I have just bought 2 Archos 2GB
MP3 players can only play music files in mp3 file format.
You need to convert your CDs to mp3 music files onto your computer or download them from the Internet and then copy them to your MP3 player using the supplied USB cable when you connect the MP3 player to the computer.
Click on this link for instruction on converting music files to mp3 file format :-
http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
Feb 13, 2011 | Archos Clipper MP3 Player
DOWNLOADING TO MEDIA PLAYER
1st of all, your Archos needs to be set to PC Hard Drive mode in the settings.
Then when you plug it into your pc, it will just show as a new drive.
You can then simply drag and drop movies, music, flash games, files etc.
The Archos accepts avi files with mp3 sound, however if you purchase the package which allows you to watch DVD's onthe Archos, then you also have a whole load of codec's which means it accepts Real Player files, Dolby Surround sound, you can copy 4.7 gb dvd's straight to it and much more.
Dec 27, 2008 | Archos 605 WiFi Digital Media Player
Archos 605 wi /fi only puts music on hard drive
A couple things to note. First.
Make sure the files are the right format.
second, make sure they are in the music folder.
third... sometimes it won't read them. you can still play them here's how:
Go on your archos go to music, than at the bottom click on hard drive.... you can play everything there.... i recommend not synching it... but dragging and dropping them in by hand... i like doing things basic...
Dec 24, 2008 | Archos 605 WiFi Digital Media Player
Nov 13, 2008 | Archos 605 WiFi Digital Media Player
Archos 605 Video Player
change another kind of converter,
Video Download Studio can meet your needs,i think
Download, convert and save videos directly from Youtube and more. Formats AVI, MPEG, MP4, 3GP, WMV, MP3, FLV, MOV, WAV.
get a free trial from http://www.downloadvideos-convert.com/download-videos-music
hope it can help you more or less!
Nov 06, 2008 | Archos 605 WiFi Digital Media Player
Down load music fom my music folder
did you rip it in itunes or wmp? it doesn't like itunes songs
Feb 10, 2008 | Archos 605 WiFi Digital Media Player
Downlaoding movies
Once you have downloaded the file to your PC simply connect your archos to your pc using USB cable provided, select PC hard drive mode, and simply copy or drag and drop from one destination to the other. Your Archos usually appears as J:Archos604WiFi if you have a built in card reader if not it may appear as an earlier letter in the alphabet.
Dec 27, 2007 | Archos 604 WiFi Digital Media Player
35 people viewed this question
Top Archos Audio Players & Recorders Experts
Marvin
Marvin
 Grubhead
Grubhead
Harrie
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
