Question about Hitachi 61SDX01B 61" Rear Projection Television
Convergency repair kit hatichi 61sdxo1b
Need to repair the ic have red double halo and color is off very yellow
5 Related Answers
Vista Electronics
  • 1694 Answers
SOURCE: Set is still slightly out of convergence after repair
Download manual & get info at www.HitachiServiceUSA.com....
Posted on Nov 10, 2007
Anonymous
  • 4402 Answers
SOURCE: cONVERGANCE REPAIR KIT FOR HIT 43FDX01B
bdent carries kits for this tv
http://www.bdent.com/kits/repair_kits.jsp
Posted on Jan 07, 2008
Slinteriors
Sonny Berry
  • 8617 Answers
SOURCE: convergence IC's
Stk 394-160 are the better IC and they are available in the DP15H Upgrade kit at the following link.
http://servicemanuals.vstore.ca/
Posted on Nov 27, 2008
ladywinn
ladywinn
  • 5138 Answers
SOURCE: 61 Hitachi Ultra Vision has double image
Replace both of your STKs big black ics If they are STK392-110s upgrade to 180s better ics Electronix has them call 1-800-223-3205
Posted on Dec 18, 2008
Anonymous
  • 65 Answers
SOURCE: red color distortion hitachi 46f500
Can't remember which this one uses but its right on the chips. Check your resistors too.
Posted on Apr 09, 2009
Double faces with red 'halo' around people...after TV 'popped' and went off then back on.
Replace the convergence ICs and resistors. You can get the JVC repair kit called the AV48WP30 - AV65wp30 convergence repair kit from www.tvrepairworld.com which contains the ICs, Resistors, and the CD with repair instructions.
May 25, 2011 | JVC AV-56WP30 56" Rear Projection...
Blue color is causing a miror effect
Ur tv convergence are dead.U must know how to solders?Must replaced 2 STK convergence ICS and some or all it resistors.Tries websites like Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
Apr 26, 2010 | Sony KP-57WS500 57" Rear Projection...
Double image, red color
you need to repair the convergence. You can get the repair kit for your models convergence at the following link. The kit has the convergence ICs and resistors plus a cd with instructions.
http://www.tvrepairworld.com/
Jul 13, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Model# AV48WP30 Picture show double vision. Colors cant be adjus
you need to replace the convergence ICs and associated resistors you can get the repair kit at the following link for your model which contains the two ICs and all the feed resistors plus step by step instructions with detailed photos how to do the repair. Heres the link to the kit for your model.
http://servicemanuals.vstore.ca/product_info.php/pName/av48wp30-convergence-repair-kit/cName/convergence-repair-kits
Mar 05, 2009 | JVC AV-48WP30 48" Rear Projection...
Funny colores and shades on my Toshiba projection TV
the convergence tube is the faulty part in this case a new convergence tubes replacing is required.
Jan 30, 2009 | Toshiba 42H81 42" Rear Projection...
Apex 51' gb5108
Just click below for convergence repair kit;
Double images and colors are blurry .Blue,red and yellow wave coming up from the bottom of the screen on the lower left and fuzzy images this is a symptom is for busted convergence IC,you must replaced this IC in order that will works better again.STK 392-xxx ICs and it's associated resistor,this resistor automatically change value,can caused truoble even though you change the ICs.If you bring this to a service center they cost you $600 to $700,but if you buy the repair kit you can save more,don't wory it is very easy because there is intallation guide including in the repair kit. Feel free to ask whatever the result... click the link for sample picture guide step by step installation;
Hope this may help;
Regards,
VOTIT
Oct 10, 2008 | Apex Digital GB5108 51" Rear Projection...
Too much red!
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem. Doing so will only make things worse. The blog does however show you how to fix other common problems with these sets.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Oct 08, 2008 | Hitachi 53SDX20B 53" Rear Projection...
Double Images
Double images and colors are blurry .Blue,red and yellow wave coming up from the bottom of the screen on the lower left symptom is for busted convergence IC,you must replaced this IC in order that will works better again.STK 392-xxx ICs and it's associated resistor,this resistor automatically change value,can caused truoble even though you change the ICs.If you bring this to a service center they cost you $600 to $700,but if you buy the repair kit you can save more,don't wory it is very easy because there is intallation guide including in the repair kit. Feel free to ask whatever the result... click the link for sample picture guide step by step installation;
Hope this may help;
Regards,
VOTIT
Oct 02, 2008 | Sony Grand WEGA KDP-65WS550 65" Rear...
Convergence problem
replace the convergance ic chip on the board below the crt of whtever color is not working
Aug 29, 2008 | Sony Grand WEGA KDP-65WS550 65" Rear...
Phillips Model 60pp920217f
No. your problem is related to the coolant in the green CRT has congealed with bacteria and needs to be changed. Thats what causes the halos and general poor picture and color quality. The blue should be changed also. The red for some reason doesnt seem to be affected by the bacteria problem. This is a common problem that happens with all projection TVs phillips and magnavox TVs
May 12, 2008 | Televison & Video
Hitachi 61SDX01B 61" Rear Projection Television Logo
Top Hitachi Televison & Video Experts
Paul Bade
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
