During the intial boot process, do I press the F2 or the F12 key? What does each key mean? I look forward to a solution to allow the boot process on my computer system.. Sincerely yours, Clinton
SOURCE: MONITOR GOES BLANK
Did you recently change or install a program that would affect the resolution and card output? Try booting into safe mode by holding the "shift" key during boot. From there right-click on the desktop and hit 'properties'-> 'display properties' -> 'settings' , check your resolution and drop it to 800x600 and then reboot. If everything goes back in normally make sure you have the right windows drivers for your video card. You can also check the driver version and settings while you're in safe mode. Sometimes the windows update drivers can act screwy and I would recommend getting them directly from your card manufacturer.
SOURCE: Dell dimension E310 wont boot
Go in bios and change the SATA mode to IDE or compaitibilty then check whether it is working or not
SOURCE: Dell Dimension 4550,System keeps trying to reboot
Use your installation CD for Windows that came with your computer, and boot to the CD. (Usually, pressing the F12 key will offer your boot options such as "Boot to CD.")
Once booted on to the CD, it will offer you several options - Do not reinstall Windows - you want to choose the Repair Option.
When the repair stuff has loaded (You may have to select which volume you wish to work on, if so just pick the number that is next to your C drive.) and you are at the prompt that looks like "C:>" you will want to type in the following, without the quotation marks.
"chkdsk c: /r"
It will take a while for it to work all its magic, but that should fix your problem!
When it is finished, you can simply push the power button on your computer to turn it off.
When you next turn it on, it should be happier!
SOURCE: my dell dimension 3000 goes to blank screen after
Have you tried starting in safe mood and then ran a scan of the hard drive, it could possably correct any file errors that the start up files may have Hope this Works Steve
SOURCE: Dimension 8400 locks up. Keyboard won't respond.
Generally and indication of a software issue that is locking the system. There can be hardware causes too.
Usually, to enter the bios, you have to press either of the following keysF1F2F10Try logging in with safe mode.This could also be a virus issue as some of your system file may have gotten corrupt or infected. Run an anti-virus in safe mode.Also, use previous settings that worked in your bios.Awaiting feedback
