Question about Brother MFC-5440CN All-In-One InkJet Printer
Brother mfc j220 disassemble - Brother MFC-5440CN All-In-One InkJet Printer
Posted by mrkjsphdelro on
4 Related Answers
Geekman
Chris Hingee
  • 32281 Answers
SOURCE: my brother mfc j220 canoot
It looks like the magenta print head nozzels are blocked.
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Posted on Sep 06, 2011
David Purtle
SOURCE: I purchased a brother mfc-j220 24/5/12 that has the printing preferences in German. I need these to be in English as I am in Australia.What's your problem?
When you loaded the printer driver you may not have selected English as preferred language when asked the question in the driver install process
You may have to uninstall & then reinstall the printer driver
However, as a first step go to the printer icon, right clik, go to properties and see if you can fine a language choice on the printer properties Tabs / options
Posted on Jun 03, 2012
Res Yarcia
  • 60 Answers
SOURCE: bagaimana mengatasi unable to clean 50 brother mfc-j220..?
Check the description of your problem.
Posted on Apr 27, 2013
arn14052003
arn14052003
SOURCE: Brother MFC-J220 ink absorber full
pls help me dis prob
Posted on Aug 27, 2013
How to reset ink absorber full for brother mfc-j220
https://www.google.co.uk/search?es_sm=122&q=BROTHER+PRINTER+MFC-J220+INK+ABSORBER+FULL&spell=1&sa=X&ei=L7HgVMfAA5HLaJP-gJAD&ved=0CBwQvwUoAA
2helpful
Brother MFC J220 unable to print 73
The cap lift cam switch is defective. you will need to replace either maintenance unit or the ASF motor assy
I need OCR for MFC J220,how to get it?
Go to the Brother Solutions Center for your country or region. In the download page, download the full software suite for your OS. It should have a version of the ScanSoft application.
Unable to clean 5A for brother printer MFC J220
check for ink levels and also check for rollers and usb connections drivers etc
BROTHER MFC-J220
You may download software and drivers from here.
IMPRESSION IMPOSSIBLE .4F
change your print head, and the printer will work perfectly.
when changing print head don't use chineese ink, use brother original ink, to save your head,
Hot Sell Printhead For Brother Mfc J825 Print Head Buy New And Original... Printhead Mfc j220 Mfc j615w Mfc j410 Dcp j125 Printer Head Buy Print Head...
6helpful
UNABLE TO init48 BROTHER MFC-J220
I think the printer head need to be replace
Brother MFC-5440CN All-In-One InkJet Printer Logo
Ekse
k24674
