SOURCE: ICD-B500 Recorder
An adapter will not fix the problem. The files cannot be transferred to a computer using a USB port. The files must be transferred analog using the recorder's headphone cord. The files are then recorded to the computer from the Sony recorder using a program such as Windows Recorder. The ICD-B500 has many great features but archiving to a computer is not one of them.
SOURCE: recover erased data
Ok,
Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
SOURCE: I accidenlty erased files from Sony ICD-P320
dear sir,
sorry you can't recover it. because, it contains flash memory that's why it's not possible.
thanks
SOURCE: transfer digital recording to computer to make CD
As there is no USB port on this IC Recorder, you can connect the Headphone OUT of the IC Recorder to the LINE IN of the Computer. Then, use any Sound Recorder Software to capture the files. You can also use the Sound Recorder Software preinstalled in the Computer. After transferring the recordings to the Computer, you can use any CD Burning Software to burn the files to a CD.
SOURCE: There is no on/off button on the ICD-B500, so how
As you say there is no on/off button on the unit. The display is on at all times. If you look at the instructions under the heading "3 Set the time", there is a tip that states this. Here's a link to the instructions:
http://www.fixya.com/support/p201161-sony_icd_b5_handheld_digital_voice/manual-16274
