Washing machine is spinning fastest enough to slosh water out the top and on to the floor, but not emptying normally.
SOURCE: washing machine won't spin
The lid switch is likely defective. Test with a VOM meter and replace as needed.
SOURCE: fisher and paykal IWL16 washing machine showing
Hi just read your posting.Error code 37 means PUMP BLOCK ERROR.Drain some of the water by hand enough to look under the machine to the front right.Do you see a fan.If you do this is your pump.If you do not see a fan then you have the new style of pump.Please reply on which style of pump you have and I will guide you in rectifying this fault.Looking forward to your reply.
