SOURCE: Re-starting a ARRIS modem after a loss of power
You can try doing a "Hard reset" on the modem but it looks like you've tried most combinations. To do the hard reset: - unplug the coax cable from the back of the modem - Push and hold the "reset" button in for 15 seconds - Allow the modem 30 seconds to reinitialize and then plug the coax cable back in. Within 10minutes you should have activity back. If not, the modem needs to be replaced. I know you may have tried something similar to this but I'm hoping this may help.
SOURCE: im having problems
Your modem is not synching. It could be a number of possibilities, and you're going to have to do some troubleshooting to narrow it down.
SOURCE: cable modem + dlink router
Your modem needs to be rebooted in order for your router to pull an IP from the modem. To do this, look for a little hole in the back of your modem and use a pen to push the button. Wait for the reboot to finish and then try again in about 20 seconds.
SOURCE: ONLINE light is off, power, receive and send are on.
Online
Flashing - Scanning for a network connection.
On - Startup process complete. Modem aqcuired.
No online means no connection to the cable company DHCP server
the most easy way to connect to the internet is get a bluetooth connetion (zippys) press the tools find device on the bluetooth on ur phone press pair device and press dial up inthe username put ur mobile number and password mobile number dial up number *99# dial
