One of the leds that light up the screen (found around the edges of the tv) in a corner of my tv has gone out. At first it went out, came back and kinda had issues. Now it is completely out and the corner of my LED is dark. Any ideas how to fix this?
SOURCE: Westinghouse W33001 Will not power on
I had that happen to my tv and took it to be repaired and it was the power pack where it attaches to the tv it just like snaps on and will arch and burn the power pack and it wont power on so the repair guy charged me $89 parts and labor he put one in but sodered it so it will not draw moisture and arch and it works great now....
SOURCE: i just purchased a westinghouse lcd led tv. half
This sounds like a series of LED's are not performing properly and may indicate a faulty set. I would recommend returning for a replacement.
Testimonial: "simple solution just wanted some reassurance. exactly what i though but good to hear from an expert"
SOURCE: when installing a wall mount on a westinghouse
Depending on the model you have you might need ether the inverter board or you might actually need the power board. You are likely to find both these parts at www.shopjimmy.com or by emailing [email protected], you should always have a certified technician fix your TV but it doesn't take a rocket scientist to change ether of these boards.
SOURCE: TV LED 26' Westinghouse looking for activation
Hello Musiclab, to get the activation code you can do one of two things, call the toll free # 1-800-701-0680 or send me a quick email to [email protected], include the model # as well as the serial # and I will give you the activation code if you have not yet received one. Also once we are done please rate my answer.
SOURCE: Year old Westinghouse sk-32h540s TV
It really sounds like you are having the problem with the main board which get the control signals from the remote and side buttons and it is not processing those signals right now. You should inspect the main board voltages which you will need service manual to do that.
Here are the replacement boards
http://www.shopjimmy.com/catalogsearch/result/?q=Westinghouse+sk-32h540s+
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
