Where i can find a free schematic diaagram for aoc 5En?
SOURCE: AOC 53N PROBLEM
DO YOU KNOW HOW TO SOLDER. IF SO, TRY TO OPEN THE MONITR AND LOCATE THE VERTICAL SECTION AND YOU WILL FIND LOOSE SOLDERS. A SINGLE HORIZONTAL LINE MEANS THAT THERE IS A PROBLEM WITH THE VERTICAL LINEARITY OF YOUR MONITOR. FIND SOMEONE WHO KNOWS HOW TO FIX COLD SOLDERS
SOURCE: no power dead set 5en aoc monitor
just try to change the horizontal transistor C5386 or CXXXX... with a new one....
SOURCE: need schematic diagram for AOC 5 En model (white
my AOC crt monitor 5En model has this problem. it has over width the compress button (<> ) is no longer functioning what particular component should i check or adjust inside the circuit? please i need ur help..
SOURCE: AOC color monitor 15in. 5En model.
u try to reorient ur vga connection it might be a loose connection between ur monitor and ur cpu otherwise ur vga cable is defective...
