I have a Bonaire B016RT which has stopped cooling. The word reset is showing on the Vulcan Comfort Control remote which I have tried on numerous occassions but it still won't cool. I have had an air con serviceman out to my house but he needs to know what the fault code 08 means. Can anyone help?
Joe Ball
    Master:
  • 589 Answers
Sounds like your "air con" man is the one whom needs help.
Posted on Jan 18, 2018
5 Related Answers
dustin358
  • 30 Answers
SOURCE: control panel lights constantly flashing
You should have a dedicated line that feeds the equipment power look at your main electrical panel or search around your equipment for a pull out disconnect switch or sometimes they will wire it to a light switch. by shutting down the main power and turning it back on it should reset anything.
Posted on Jan 05, 2009
pierre1811
Perry Putnam
  • 144 Answers
SOURCE: Vulcan-Bonaire : summer breeze
This unit is a cooling unit only. I don't know what switch you are looking at but I don't think it's for the evap. cooler(swamp cooler). I am in the Phoenix, Arizona area and it's very common to have a evap. cooler and a seperate heat/cool system as on the hottest days the evap. cooler doesn't cool enough. I hope this helps. Please give me a positive rating. Thank you.
Posted on Jan 29, 2009
Ashley
  • 40 Answers
SOURCE: i have a bonaire evap
Remotes are a pain. Can you get into the unit to see the control box? You need to see if the unit has power. If its new enough it will have some diognostic lights so you can see if it has power. Without that its hard to diognose. Unit Model number is also helpfull. if it looks like the one on this picture it will be etched into a badge on one of the corner pillars. if its a plastic unit it will be on a sticker inside the unit
Posted on Apr 04, 2011
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: Vulcan gas ducted heating systemr
The reason the heater is cutting out is because it is getting too hot or it thinks it is too hot...
Check the filter and also that enough air vents are open so it can move enough air....make sure the gas pressure is correct and that the flame is not too high. Check that the blower is working correctly and starting up when it should. Check the post purge... make sure the blower is running to remove residual heat after the flame shuts down.
If all that checks out then you may have a bad sensor or control module, but they are much more difficult to troubleshoot.
Bottom line is that for some reason you are either getting too hot or the furnace is sensing too hot of temperatures and shutting down.
heatman101
Posted on May 24, 2011
luke ortisi
SOURCE: Our Bonaire Evap Cooler stopped after power failure
you need to turn off power supply to unit that works ok and leave other unit switched on and code it and test it then switch other unit back on
Posted on Jan 30, 2012
Bonaire Vulcan controller cct board 10 amp fuse keeps blowing
Obviously a direct short. Take pic, remove all wires, replace fuse. Wire by wire, turning power back on each time until fuse pops. When it does, there's your problem.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jun 02, 2017 | Vulcan Heating & Cooling
Bonaire vulcan comfort control
No it cant really be fitted as the evap system uses much larger duct and also in some cases people use a different type of duct that when running a gas heater threw it it tends to melt with the heat. Your best option would be to get new ducting that way you can size it correctly so you dont have air alance issues down the track.
May 10, 2014 | Heating & Cooling
How do you change the zoned sections on the control panel/remote
you need to do the programming of the Zones with in the first 5 min after powering up tghe unit threw the wall controller
Apr 27, 2014 | Heating & Cooling
I have a Vulcan Bonaire ducted heating system with Comfort Control in a holiday house, installed in 2006. It was working fine last time we used it about a month ago. Today every time I try to turn the...
hi,
The heating coil itself have some problem that's why the circuit breaker clicks off by sensing over current drop. Check the heating coil and replace it.
ok
Jun 11, 2011 | Heating & Cooling
Vulcan ducted heating system 530 E (5 years old) have replaced AAA batteries on remote control but still not working. Thanks Michael
You have to recode the remote to the heater if the batteries have been removed for more than 3 minutes. On the comfort control will the remote is in a off state turn the heater off at the power.
While off press and hold the up button and the on/off until code appears then release buttons and turn the power back on to the heater.
When code disappears from the remote turn on the remote set the temp higher than current temp and combustion fan should start up then heater will fire up.
If not repeat process as they are easily corrupted by other remotes.
Download control manual from - http://www.bonaire.com.au/support/documentation/owner/default.aspx
Set / check fan speed or it may overheat.
May 17, 2011 | Heating & Cooling
Servicing
Yes I would think so,a good r&r cleaning,once a year.
Nov 16, 2009 | Heating & Cooling
Bonaire Cooling system that stopped working after power failure..
Unplug the unit or turn off the breaker to the unit for at least 30 seconds. If this reset does not work, the electronics may be damaged and need a repair person.
Jan 30, 2009 | Mastercool 67471 Evaporative Cooler Air...
Heating & Cooling Logo
230 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
