HITACHI AXM 140 SYSTEM
I HAVE AN HITACHI AXM 140 SYSTEM. THE PROBLEM I HAVE IS THAT WHEN YOU TURN IT ON THE DISPAYS KEEP CHANGING FROM DVD TO MP3 TO DAB,ETC.CAN YOU PLEASE ADVISE
  • 5,370 Answers
Try to reset the system.For reset procedure,click the link below :-----http://technoanswers.blogspot.com/2012/01/hitachi-ax-m140-system-display-keeps.html
---------This will help.Thanks.
Posted on Jan 27, 2012
I need to convert to a region free version for the Hitachi P315U
dvd player will only play movies for the COUNTRY in which you purchased it. There is no way to purchase a system or configure a system to play ALL MEDIA FOR ALL COUNTRIES. The country codes are specific and each country wants to prevent any other country from playing their dvds music, etc
Jan 23, 2011 | Hitachi DV-P315U DVD Player
My mp3 palyers says its 2 gigs but wont hold anything over 140 songs and when i chceck the memory it saying it got a gigabyte and a half left
Over time MP3 players lose memory even my 1 terabyte hardrive suffers from this problem but an easy fix is to try defragmenting the memory drive
hope this helps
Jan 04, 2011 | Hitachi Audio Players & Recorders
Can a hitachi ax-m133 be upgraded to dab +
if the hitachi unit has a line in socket, you can plug an additional DAB tuner in to give you dab.
Sep 20, 2009 | Audio Players & Recorders
Setting the clock?
select the slide on the top to set clock, then use minutes and hour buttons to adjust accordingly, slide to alarm and repeat, press set button if no slide, also, have alarm set to buzzer/radio accordingly, and alarm 1/alarm 2 accordingly if applicable.
Oct 20, 2008 | Audio Players & Recorders
How do i reset a HITACHI AX-M131U DAB/FM/CD/USB/MP3 MICRO HI-FI SYSTEM i want to retune it
push the funtion button till dab bomes up on the screen then push in the info button and it will start to retune dab. for a total reset just push the select button 1 second after you hold the info button for 5 seconds
Mar 09, 2008 | Audio Players & Recorders
Need instruction booklet for HITACHI AX-M138 USB DAB CD DVD MP3 HIFI SYSTEM. Bought on Ebay and didn't come with instructions
I have found out that the Hitachi AX-M138 was only ever distributed in the UK by DSG (Dixons / Currys) so you could try their spare page at www.mastercare.co.uk to see if they can supply you with a manual. I've had a look & they no longer list it but it's worth an email to them. Otherwise I have a copy if your interested.
Jan 23, 2008 | Audio Players & Recorders
Matsui MAT 140 MR wont turn on
If you can check the rechargeable batteries try that. If you plug it into a wall socket with the adapter and nothing happens you might have other major problems. Just a little education: when you buy something especially from other countries alway check it before leaving to make sure it works. Unless there is a company that you can send the warranty unit to you may be out of luck. Sorry.
Jan 14, 2008 | iLO (2 GB) MP3 Player
SET UP GUIDE
I am sorry to say that there is no way for you to get into the region selection menu once you have changed your region once . The only people who can fix/change this for you are the folks at Hitachi. It's a pity that you changed your region from all to 2...I always prefer all regions...
Dec 25, 2007 | Audio Players & Recorders
375 people viewed this question
Ekse
 Grubhead
Grubhead
