I have an Elna Carina Electronic Type 65 sewing machine which is more than 25 years old but sews great. I would like to purchase a double welting presser foot. Will any low shank presser foot work? I found an Elna snap on, however the website does not list my sewing machine (too old?). Are all Elna snap on presser feet interchangeable?
Snap-on feet will work as long as you have the correct snap-on shank for your machine. The only problem might be, for example if the snap-on foot is for a 5mm machine and you have a 9 mm machine, but that is unlikely in your case.
Yes, any low shank should work. If it doesn't you can always regift it to someone.
SOURCE: my Elna Carina 65 doesn't feed fabric . I've
Is it possible that you've lowered the feed dogs and not raised them again? Is the stitch length dial set to 2.5 and not on a buttonhole blue setting or the Automatic "A" setting?
SOURCE: Hi, I have an Elna Carina and the flywheel is
I can direct you to a service manual for your machine but it may be something that you need a trained Elna service technician to deal with.
Link is http://www.arizonaexpressionz.com/elna_service/air_elec_carina_elec_SM.pdf
I am more familiar with the SU air electronic where you just hold the outside of the flywheel and turn the inside knob to disengage and rengage the clutch - didn't realise the Carina had a button flywheel release until I looked in the service manual.
Anyway, you could try dismantling the flywheel following the exploded diagram in the service manual if you are technically minded.
Or just take it to a reputable serviceman, I'm a big fan to supporting these guys as their knowledge is invaluable.
