Chef cooktop
SOURCE: chef cooktop wiring
make sure that the white wires are indeed line and not neutral and you probably have the right idea but without a wiring diagram or seeing the unit I cannot confirm this just make sure you aren't hooking up line voltage to the neutral on the unit. also your service has only three wires correct? this means you are piggy backing the neutral and chassis ground (green wire on appliance) not cool on a trailer or manufactured home be careful bud
SOURCE: Chef Electric Hotplates
Never...ever change the fuse rating upward on an existing circuit to accomodate a new appliance. The fuse is a protective device designed to limit current to the level the wiring can safely handle. There is a strong possibility of fire at some point!!!!
If you are rewiring, most places require up to 30 amps for cooktop wiring anyway. Use #10 copper wire for that purpose. If you are doing this yourself, make all connections tight and install all grounds.
SOURCE: Chef Supreme Co-ordinate Series Ser. No.:
this could be a 220 v unit and one side of the lines is out . ck your power at the breaker and at the cook top . if power is ok I would think it's the control sw . and not the plate .. you will need a volt /ohm meter to test . whirl / g e / frigidair / have genric switches that should replace yours .. hope this will help mm
