Question about VinoTemp (VT60GNV) Wine Cooler
Vinotemp VT60 Freezing
LL on display and freezing
Posted by Paulette Barker on
raj somaiya
  • 5,370 Answers
For LL error code,click the link below :----http://technoanswers.blogspot.com/2012/01/ll-error-on-vinotemp-wine-cooler.html
-----------Thanks.
Posted on Jan 26, 2012
My vinotemp vt60 starts cooling then stops
I sounds to me like the compressor is overheating. There is an overload on the compressor itself. Follow the wires where they go into the compressor. There will be a black wire going from the power cord to the overload. These can be purchased at appliance parts stores. Make sure there is no dirt build up on condenser coils or a kink in the tubing.
Jul 30, 2014 | VinoTemp (VT60GNV) Wine Cooler
VinoTemp is displaying "L L"
hi there
what exactly are you seeing now? what exactly is happening?
i have here a pdf of vinotemp and it has some error written.
http://www.vinotemp.com/winmate_instruction.pdf
Jan 24, 2008 | VinoTemp (VINO-24GN)
We have our unit in mexico and it has been working perfectly since 2004 up until today. As of today the lights are on but it is not cooling. I try to turn the temp down but it just flashes and then shows...
Here is the link to the main Vino Temp Online Support page with all the service manuals, troubleshooting guides and user manual.
http://www.vinotemp.com/Service-Support/Troubleshooting-Repair.aspx
Here is the direct link to the Troubleshooting Guide:
http://www.vinotemp.com/Resources/Documents/VT60.pdf
And here is the direct link to the Detailed Service Manual:
http://www.vinotemp.com/Resources/Documents/SERVICE_MANUAL_FOR_VT182.pdf
If you have a digital multimeter (voltmeter) and a screw driver then you can do most of the troubleshooting yourself. You should be able to tell if it is a controller board problem or a refrigeration compressor problem just by following the instructions in the guides.
If it is a control board problem you should be able to fix it with just a soldering iron, or if you need new parts, they should be available on Ebay.
If the problem is with the refrigeration compressor then any refrigeration technician (even in Mexico) should be able to fix it. Especially if you provide him with the service manual above.
Good luck and please comment back and rate if this was helpful or if you need further assistance.
Thanks.
Joe.
Feb 12, 2011 | VinoTemp VT-60 Wine Cooler
Unit runs the whole time
Try cleaning the condenser area. Removing int and dust will improve performance. If the wine is freezing that is a bad cold control. An easy fix.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 30, 2010 | VinoTemp TC-180SS Wine Cooler
I have Vinotemp wine chiller model number VT-21TEDS-2Z. It is Dual zone and the bottom zone temperature is to low. I set it to 60 but it is at 49. The temperature controller does not seem to control it.
It will either be the thermal resistor or the controller of which the electronic thermostat is a part and yes it can be repaired. It is a reasonably common and cheap fault to repair. If you go to the following link you can get the service manual FOC
and you can contact a repair company via Vinotemp at the following link
http://www.vinotemp.com/Service-Support/Repair-Companies.aspx
Nov 07, 2009 | VinoTemp (VINO-24GN)
Vinotemp (VT-60), cools, but doesn't turn off regardless of the temp setting. It will run, cut off for aprox 5 seconds, then continue running. Is thermostat broken? Can it be repaired?
Nov 05, 2009 | VinoTemp VT-60 Wine Cooler
My Vinotemp VT60 makes a clunking sound
You may want to contact Vinotemp's customer service @ 800-777-8466... you may need a new compressor
May 06, 2009 | VinoTemp VT-60 Wine Cooler
Wine-cicles
I found the vinotemp trouble shooting webpage that has good info for several different VT models. Here is the link. http://www.vinotemp.com/troubleshoot_pdf.htm
I emailed VT and they gave me a price for the parts
VT-TC32ECB -$34.95 (control board)
VT-60Sensor -$14.95
here is their services information
Jane Barron
Service Department
VINOTEMP INTERNATIONAL
[email protected]
T 310.886.3332 x231
800.777.8466
F 310.886.3310
Mar 18, 2008 | VinoTemp (VT60GNV) Wine Cooler
VinoTemp (VT60GNV) Wine Cooler Logo
1,079 people viewed this question
Top VinoTemp Furniture Experts
jasbo
jasbo
John Tripp
John Tripp
ray gallant
Are you a VinoTemp Furniture Expert? Answer questions, earn points and help others
