Intel DG31PR Motherboard Logo
Posted on Jan 26, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cmos battery error failure
When I turned on my computer, there is a notification came on screen that "CMOS Battery Failure", due to this error I observed that my computer do not show the actual time & date, it shows 12:00 AM, 01-Jan-2005 which is I think default time & date assigned in my computer.. please guide me accordingly
Anonymous
Level 3:
  • Intel Master 32,281 Answers
  • Posted on Jan 26, 2012
Anonymous
Intel Master
Level 3:
Answers
32281
Questions
Helped
7912212
Points
102259
The CMOS (BIOS) battery keeps the computer'a comfiguration and the Date & Time settings in the CMOS (BIOS) chip in its memory. When the CMOS (BIOS) battery is flat these configuration information is lost.
Replace the CMOS battery with a new one, in most cases this battery is a lithium 3 volt battery type CR2032 and it is coin size battery 18mm in dia.(check it to make sure the type of battery is installed on your motherboard).
When you replace this battery then go into the BIOS and set the Date & Time etc.
5 Related Answers
Anonymous
  • 23 Answers
  • Posted on May 24, 2009
SOURCE: firmware has detected cmos battery failure even after changing the battery
If you have basic knowledge with electronics or that you know the basic shapes of electronic parts, look for a busted electrolytic capacitor on your mobo...it may look bloated or discolored. It can be found near the coin battery. Ask for an expert electronic technician to replace it. If it is still under warranty, have your mobo replaced with a new one.
If your mobo has its circuitry doing fine, you will need to update your BIOS software. Have someone assist you on this especially those who are computer engineers.
Anonymous
  • 34 Answers
  • Posted on Jan 22, 2009
SOURCE: I HAVE CMOS BATTERY FAILURE
You can find a replacement battery at any local retailer that sells battery watches. If there's a walmart in your area you can go there. Just take the dead battery with you so you can get the correct replacement.
Anonymous
  • 272 Answers
SOURCE: cmos battery failure even after changing the battery
may be the replaced battery is not working too. please try another battery or first make sure, the battery you placed is working ok.
Anonymous
  • 1901 Answers
  • Posted on Oct 05, 2009
SOURCE: cmos checksome error
Looks like your CMOS battery may be getting weak. Note the number and voltage on the battery on your motherboard, usually about the size of a quarter, and replace it. When you first boot up after replacement you need to go into the BIOS because the CMOS settings need to be set/verified and do a Save & Exit.
Note: Before replacing the battery, turn power OFF, unplug the power cord, and press and hold the power button for 5 seconds to "bleed" any capacitors.
Thanks for using Fixya.
clokker
markus
  • 253 Answers
  • Posted on Aug 10, 2010
SOURCE: my computer(P4 1.7Ghz,Intel 945wn MB,
update the bios.Find out the motherboard number.
than go there http://downloadcenter.intel.com/Default.aspx
find the bios and install it.Take care with that.Do not shut down under
the install process...
How do i remove and replace the cmos battery
If your computer is losing its time or date settings, or you are receiving a message CMOS Read Error, CMOS check sum error, or CMOS Battery Failure, first try leaving the computer on for 24-hours. In some cases, this can charge the battery and resolve your problem. This fixes most CMOS battery issues on computers left without power for several months. If this does not resolve your problem follow the steps...
http://www.computerhope.com/issues/ch000239.htm
How to replace cmos battery on compaq presario 3070us
My HP CMOS battery is under the Memory mods. On the bottom of the laptop you will see the memory bay open and take a look . Try the manuals here for more info: http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&lc=en&product=326334&
Will not power up
DELL BEEP CODES
Beep Codes Beep Code Description Failure Coverage 1 System Board: BIOS ROM failure System Board, covers BIOS corruption or ROM error 2 Memory No Memory / RAM detected 3 Chipset Error (North and South Bridge Chipset DMA/IMR/ Timer Error for Intel platform); Chipset Error System Board Chipset Failure Time-Of-Day Clock test failure. Gate A20 failure Super I/O chip failure Keyboard controller test failure. 4 RAM Read/Write failure Memory failure 5 RTC Power Fail. CMOS battery failure 6 Video BIOS Test Failure Video card / chip failure 7 CPU Cache Test Failure CPU failure 8 LCD LCD failure
2helpful
Cmos Checksum Error
Check CMOS and Memory Modules:::If the error message is "UNEXPECTED_KERNEL_MODE_TRAP," then it indicates you have problem with the memory of your computer. You need to check whether the SIMMs (Single Inline Memory Modules) are compatible and have the same speed. Secondly, also check whether you have set the CMOS (Complementary Metal Oxide Semiconductor) to the right amount of RAM. If these solutions do not work, you might have to replace memory in your computer....try to use system utility tool like Reginout.. Hope the problem is resolved.
My girlfriends Hp Pavilion A305W powers on then automatically powers off after it show a brief error message but also says F1 for startup. Should i press F1 and continue diagnosis?
Most probably your system is not getting your BIOS settings from your mainboard due to CMOS battery failure.
Check your CMOS 3.0v battery & replace it. Then reconfigure your BIOS settings from the CMOS setup.
Hope it helps
''Firmware has detected cmos battery failure''
CMOS battery in the motherboard much measured .3 volt which is a Lithium coin cell battery.check whether the battery gives the correct measurement (recomend to use branded battery like from sony).
if the measurement is correct then reset your BIOS setting by removing all the jumper in the motherboard for about 60 secs.and place it again and start your pc;set yr BIOS to default setting,
let me know if it comes handy to you
2helpful
My hp pavilion a1330n computer freezes on the HP
the dreaded Blue-Screen of death.
Usually caused by:- Ram Failure ( memory Modules )
CPU Failure ( Processor Failure )
Hard-Disk faulty, not spinning et,c.
Cmos battery fault.
Missing/deleted/corrupted operating System files.
Possible Solutions:- remove cmos battery, from Motherboard for 10 seconds and replace. ( eliminates cmos/bios errors )
remove 1 stick of Memory ( Ram ) and test individually ( eliminates 1 or More Faulty sticks Of memory Or Slots )
remove, CPU Fan/heatsink, remove CPU and re-seat, re-grease with Artic-Silver or similar ( thermal-Compound ) replace heatsink/Fan. test.
Hope this points you towards a Sucessful repair.
Mike @ Compurepair. No-Links No-Nonsense Just Good Practical Advise :-)
1helpful
2answers
I have a Dell dimension 9150 which is 2 1/2 years old. Does it have a battery that I need to be concerned about replacing. I remember that used to be a problem with computers but don't know if that is...
Every PC motherboard has a battery. That battery serves two purposes: to feed the configuration memory (also called CMOS) and to feed the real time clock of the computer (the one that show the date and the time).
An indication it is time to change the motherboard battery is receiving one of the following error messages when you turn on your computer: CMOS CHECKSUM FAILURE, CMOS BATTERY STATE LOW, CMOS SYSTEM OPTIONS NOT SET and CMOS TIME AND DATE NOT SET. Another indicator of a low battery is a clock that, after being set, runs well while the computer is on, but shows the wrong time when the computer is turned on the following day (it is late).
Chassis intruded!!
Clear RTC RAM (CLRTC)
This jumper allows you to clear the Real Time Clock (RTC) RAM in CMOS. You can clear the CMOS memory of date, time, and system setup parameters by erasing the CMOS RTC RAM data. The onboard button cell battery powers the RAM data in CMOS, which include system setup information such as system passwords.
1. Turn OFF the computer and unplug the power cord.
2. Move the jumper cap from pins 1-2 (default) to pins 2-3. Keep the cap on pins 2-3 for about 5-10 seconds, then move the cap back to pins 1-2.
3. Plug the power cord and turn ON the computer.
4. Hold down the <Del> key during the boot process and enter BIOS setup to reenter data.
Except when clearing the RTC RAM, never remove the cap on CLRTC jumper default position. Removing the cap will cause system boot failure!If the steps above do not help, remove the onboard battery and move the jumper again to clear the CMOS RTC RAM data. After clearing the CMDS, reinstall the battery.
You do not need to clear the RTC when the system hangs due to overclocking. For system failure due to overclocking, use the CPU Parameter Recall (C.P.R) feature. Shut down and reboot the system so the BIOS can automatically reset parameter settings to default values
Top Intel Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
