Computers & Internet Logo
Sagar gurung Posted on Jan 26, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When to change CMOS battery? - Computers & Internet
Anonymous
Level 2:
New Friend:
  • Expert 85 Answers
  • Posted on Jan 26, 2012
Anonymous
Expert
Level 2:
New Friend:
Answers
85
Questions
0
Helped
19766
Points
148
You will need to change the battery just when the computer says something like this "System CMOS checksum bad - Default configuration used" or also could say something like "CMOS battery low", etc. That's the time to change the battery.
Undefined error code 87
Error code 87 typically indicates an invalid parameter or incorrect command-line argument in the context of Windows API calls. However, the context you have provided is related to changing the CMOS settings, which is related to the BIOS (Basic Input/Output System) and not to the Windows API.
If you are unable to change the CMOS settings, it may be due to several reasons such as the CMOS battery being low or dead, a hardware issue with the motherboard, or the settings being locked by the manufacturer or system administrator.
To troubleshoot this issue, you can try the following steps:
  1. Replace the CMOS battery: A low or dead CMOS battery can cause issues with changing the CMOS settings. Try replacing the battery with a new one.
  2. Check for hardware issues: Check the motherboard for any visible physical damage or loose connections that may be causing the issue.
  3. Clear the CMOS memory: Try clearing the CMOS memory by removing the battery and leaving it out for a few minutes, then replacing it and restarting the system.
  4. Contact the manufacturer or system administrator: If none of the above steps work, it may be that the settings are locked by the manufacturer or system administrator. In this case, you will need to contact them for assistance.
It's important to note that changing the CMOS settings can be risky and may cause stability issues with your system. So, make sure you know what you're doing and have a good reason for changing the settings before attempting to do so.
3helpful
Does this P.C have an internal battery, and if so can it be changed
Yes, laprops have a CMOS battery and it can be changed:
Tutorial How to replace the CMOS battery in your laptop
laptop cmos battery
CMOS battery hack Laptop CMOS battery
Acer Aspire CMOS battery Acer Aspire losing date
Maybe you even cen get a video for your make and mode of laptop, introducing in a ggogle search term
Youtuba, change cmos battery, your make and model of laptop
AFTER SWITCHING ON, SCREEN STAYS FROZEN AFTER SAYING CMOS CHECKSUM ERROR- DEFAULTS LOADED
When starting your PC, the following error message is displayed:
CMOS wrong
CMOS MEMORY size WRONG
CMOS Checksum Bad
CMOS checksum error defaults loaded
Warning! CPU has been changed please re-enter cpu settings in the cmos setup and remember to save before quit!
You are prompted to:
Press F1 to resume
Press F2 to load default values and continue
This is due to the fact that the CMOS, which contain data related to the BIOS, has been reinitialized and that your PC has been reset to factory settings.
Solutions:
Reinitializing the BIOS
  • Change BIOS battery
    • If the problem persist this may be due to the fact that the battery powering the CMOS (when the computer is shut down allows the CMOS to store information), is depleted.
    • The CMOS battery is a small pin found on the mother board, you can refer to the manual provided with your motherboard to change it or have the nearby computer technician change it for you if you don't want to risk any damage.
    • More information with: Replacing the battery of your motherboard (CMOS battery)
Post back if it is not working we will be happy to help you.
Hope this helps.
Cheers!!!!
ASUS Windows 7 laptop cannot keep time! I have checked the bios, and the CMOS battery, and all seems fine. Yesterday it lost 13 MONTHS!! What is wrong?
hi charli, did you change new cmos batter , how you checked your bios cmos battery, if you not changed your cmos battery try to change and check it you may get proper time.
GOOD luck
6helpful
3answers
How do I replace a dead cmos on acer 4520LCi travelmate laptop? The laptop no longer keeps track of system time when shut off completely. Can you tell me the exact location of the cmos so I can be able to...
what you replace is not the CMOS, but the CMOS battery.
On an ACER from those years the CMOS battery looks like a coin, or a coin wrapped in plastic and connected to the motherboard.
On most models from same series the battery is located on the lower side of the motherboard, like on picture below:
On some model the battery may be located underneath the keyboard.
Here disassembly instructions for a similar model.
2helpful
2answers
CMOS Battery do no work
Just change your CMOS battery with a new one and after that goto the bios settings and update the time and dare.
After that just save the settings and then check that the warning message is coming or not.
If its coming then it means you need to change the CMOS jumper settings.
CMOS BATTERY ERROR
You said that you already bought a new cmos bat, but still theres a problem.check the cmos battery socket,power on tyour pc and go to cmos setup,optimize default setting and set time and date.
2helpful
Cmos battery?
Computer CMOS information CMOS is an on-board semiconductor chip powered by a CMOS battery inside IBM compatible computers that stores information such as the system time
How to replace the CMOS battery. Information about why time may be lost or decreasing rapidly and how to replace your computer cmos battery
Computer Battery Help The first type of battery is the backup battery, which is commonly referred to as the "CMOS battery".
Good Luck, Please dont for get to Vote/Thank You
Grand Canyon Tech
Grand Canyon Tech
