Televison & Video Logo
Question about Sanyo AVM-2506 TV
Where do i plug in my dvd player to a sanyo avm 2506
Posted by kember honeycutt on
AAA TV Service
    Sergeant:
  • 272 Answers
Get RCA cables they come in 2 or 3 conductors, Yellow andWhite for Mono and Yellow, White and Red for stereo connection.Connect the one side of the Yellow cable to where it saysVideo OUT on the DVD.
Connect the other side of the Yellow cable to where it saysVideo IN on the TV.
Connect the one side of the White cable to where it saysAudio OUT L on the DVD.
Connect the one side of the White cable to where it saysAudio IN L on the TV.
(optional) Connect the one side of the Red cable to where itsays Audio OUT R on the DVD.
(optional) Connect the one side of the Red cable to where itsays Audio IN R on the TV.www.aaatvservice.com
Posted on Jan 26, 2012
T.V ONLY HAS NO INPUTS
U need an ipad audio/video connector. One end is the plug at the bottom of the ipad, the other end is a red/white/yellow tv connector. Get a genuine apple one, not one made by other companies, or they wont work, apple has blocked 3rd parties from certain items, and thats one of them. It costs $50 new, or you can find it on ebay used for alot less, just make sure its not a cheap knockoff and its the real one.
My kid ran a magnet across the screen now there's a purple blotch along the top of the screen.
The TV needs to be degaussed.
There is an automatic degausser built in but it may NOT be strong enough.
Try this: Turn off the TV and let cool for 10 minutes. Then turn on for one minute.
Repeat the previous sequence until screen is clear of blotches.
The cooling period re-arms the degausing circuit.
If this doesn't fix it adequately, you need to find a TV repairman that has a degausing coil... these are getting a bit rare now. It would take him ten minutes with the coil to fix it.
1helpful
1helpful
I was watching my tv (sanyo) with cable hooked to it. The cable all of a sudden went out. I tried hooking up the dvd player and the tv is no longer recognizing the cable box or dvd player. I don't know...
sound like a tuner problem. there is a resistor that goes to the tuner that could of went bad 39,000 ohms i think which should have a orange white orang strips around it and a gold. anyway there is a problem with tuner. Sanyo was good about haveing a problem with tuners in there smaller sets. If you do not know anything about how to repair you probly shoud take to a shop but the total cost might be high and not worth it in the long run. think before you jump still water runs deep.
Sanyo Model AVM 3659G won't recognize DVD player
Let's try the easy one first:
  • verify the connections, normally yellow for video, white & red for audio. TV has to be set to Video 1, A/V or Channel 0;
  • in some instances, it could be a single coaxial cable. If it were so, the TV has to be set to Ch 3.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Sanyo avm 2506 tv no sound
As It only makes noise when there is no signal (without an antenna).clearly indicates that there is a problem in sound IF SECTION or loose contact in that section. your audio section section is ok as you get noise signal when there is no signal. also check remote control setting.
Hibhh
That doesn't mean anything
TV sounds like power up for few seconds then goes off
You have a short somewhere causing the power supply not to start. Most likely a shorted horizontal output transistor and maybe a flyback transformer which caused the transistor to short. It would have to be checked out by a technician to find out exactly happened. Stargazer
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
