Question about HP Media Center m7250n (ED842AA) PC Desktop
New ram recognized by bios but not by windows xp
I added two 1GB memory sticks to the two existing 512MB sticks. I put the two 512 sticks in slots 1 and 2 and the two new 1GB sticks in slots 3 and 4. Bios shows all four sticks with their correct sizes. I can boot up Windows XP but it still says I have only 1024MB of memory. How can I get it to recognize the additional memory?
Larry Ng
  • HP Master
  • 5,982 Answers
I love ram questions, (not easy)\
.5
3 GB
my guess is your windows XP virus magnet is stuffed
XP is a dead OS, and has Zero support.
not does HP support it.
so what to do.
well its super easy.
1: boot to a linux live CD or stick
if linux likes it , your XP is hosed, like all are now,hopeless.!
if linux does not like the mem. then you bought the wrong ram.
try to know that BIOS does not get the final call on good mem
all it does really is PnP the spid chip there asking what i is.
and then passes that INFO data to windows.
did you run BIOS memory test? it too is crude,
in the end only a running good windows proves any memory is good. for sure loading a huge photo shop say 5 times.
the new sticks must be 240 pin, DDR2 SDRAM
PC2-3200 MB/sec (minimum)
the must match your CPU,
the Pentium D is old.
and many memory makers do not make ram to fit old CPUs.
2005 PC,a tad old no?
the best place to get it is Kingston or Crucial.
did you? or buy fleabay crapppppp
questions did you run the PC with just 1 , 1GB stick
if that fails and beeps like made the sticks are no good.
then next 1GB stick alone, beeps again, dead pC>
yup wrong DDR2.
the Intel chip you must make happy is the i945p
at its clock rates (called speed)
do look on kingston .com first.
m7350 seem there oldest one. in this line of HP PC.
good luck finding good memory.
Posted on Nov 12, 2017
5 Related Answers
Friendajeet
Ajeet Singh Chauhan
  • 25 Answers
SOURCE: I have a Compaq Presario, model #: SR2150NX memory problem
To Be pricise ...there is no hardware problem.
The problem can be two.
1.Your computer supports max of 1.5 GB RAM.....For this check with other vendors too.
2.You have to update your BIOS.
If you can provide me the motherboard no and details i can clarify more on it
Posted on Jun 02, 2008
Anonymous
  • 260 Answers
SOURCE: increase ram
Depending on the cost of what RAM your system uses, it may be cheaper to buy 1 stick of 1 gb or go with 2 - 512's. Either way you will benefit from the increase. When buying RAM you should install a matched pair.
You can go to Crucial, Kingston or Corsair for a RAM configurator.
Good luck.
Posted on Mar 14, 2009
antiochpc
Kevin Shafer
  • 1314 Answers
SOURCE: Can I add 1GB memory chip in 2nd slot with a 512MB chip in 1st?
Each memory slot can hold DDR PC2700,DDR PC3200 with a maximum of 1GB per slot.
So, yes, this is true.
Posted on Jul 05, 2009
Anonymous
  • 113 Answers
Well in a weird situation like the one you have, i suggest inserting one of them into the Memory Bank 2 slot. After that, start up your Computer and shut it down. If it says you have 1GB then that's good. After that, put the other one in the free slot and start it up. I hope i helped, i can't think of what else would work for that.
Worst Comes to worst, just get the one that seems weird replaced with a new one from Best Buy. They should do it free of charge.
Posted on Jul 08, 2009
joecoolvette
joecoolvette
  • 5660 Answers
SOURCE: Just bought 2 1GB PNY dual Chanel memory modules
HP Support > Pavilion a1600n desktop computer > Motherboard Specifications,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00757531&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&lang=en&product=3245022
Scroll down the page to the illustration, and photo of the Pavilion a1600n motherboard.
On the motherboard illustration where it states DDR2 XMM1 (64 bit ,240-pin module), and DDR2 XMM2 (64 bit ,240-pin module), is where the two 1GB ram memory modules go.
On the motherboard photo, it is the two Blue in color ram memory slots.
The 512MB ram memory modules go into the Black ram memory slots.
[DDR2 XMM3, and DDR2 XMM4]
The Blue ram memory slots are one Channel. (Channel 1)
The Black ram memory slots are the second Channel.
(Channel 2)
You want to keep LIKE ram memory modules in the same Channel.
If you are having problems with the PNY ram memory modules, tell me what the manufacturer code is on them.
(Or if you bought them off of a website, see if you can copy and paste the link in a Comment. Believe upper right of your page.
FixYa is constantly undergoing changes to improve the website, is why I indicate that)
You need low density, unbuffered ram memory, DDR2 Sdram ram memory.
[DDR2 at either 533MegaHertz, or you can also use DDR2 at 667MHz.
PC2-4200 and PC2-5300 respectively ]
Don't try out any high performance ram memory is my recommendation, because the Voltage required by the ram memory, may not meet the factory default voltages that are preset in your computer.
[Factory Voltage default setting for ram memory for your motherboard, is set at 1.8 Volts.
Some high performance DDR2 ram memory requires 2.0 Volts, 2.1 Volts, or even higher ]
Posted on Jun 30, 2010
Memory stick upgrade 2 512, 2 1GB what order do I put them in
On the motherboard they should be labeled as to which slot is Dimm 1, Dimm 2, Dimm 3 and Dimm 4. Put the larger ones (1GB) in Dimm 1 and Dimm 2. The smaller ones (512MB) in Dimm 3 and Dimm 4.
May 06, 2012 | Sony PCV-RS620G PC Desktop
Emachines T5082 Adding 512Mb ram. Getting slot 0 installed slot 1 not installed.
Try swapping the memory in the two slots. It sounds like either one of the memory chips is bad or one of the memory slots is bad.
If you find that one of the slots is bad, then you might try just putting a 1GB Chip in the slot that works.
Apr 24, 2012 | E-Machines eMachines Desktop PC
I have 512 mg of memory. Would there be a big difference if I add a 1 gb stick and keep the 512 mb , as oppose to removing the 512 mb and replace with two 1 gb sticks?
The performance of your laptop will improve if similar memory is placed in each of memory slot.If 1gb memory and 512mb memory are placed in available slot you will only get the performance of a single 1gb memory.but two 1gb memory are used performance will be similar to a 2gb ram or more.
May 30, 2010 | Acer Aspire 3003WLCi Notebook
Existing RAM is not recognised when I add new 1GB to free slot
it sounds to me that you have parallel port memory. This means that you have to have the same, ie both stick being 1gb, or 512mb. I just fixed my aunts pc and she was having the same problem . once I installed both 512 sticks it recognized both. ^_^ hope this helps. good day
Sep 12, 2009 | Intel D102GGC2 Motherboard
P5RD2-VM recognises only 2 GB
According to Asus, the max supported memory is 2 gig. That second stick of 512 is not needed and the error shown is in memory configuration.
Hank
Aug 03, 2009 | ASUS P5RD2-VM Motherboard
Adding memory, new total not recognized: IBM Thinkpad R51e-1844
Ram should always be paired. Same type, speed and size in each slot. You may have 1 SIMM/DIMM/DDR that has 2 sides of chips and the other with 1 which will do exactly what you state. RAM reads across the chips simultaneously. So if you have a different one in each slot it can go bonkers and do goofy stuff on you.
Jun 14, 2009 | IBM ThinkPad R51 Notebook
Compatability of Memory Upgrade
DDR RAM needs to be installed in pairs, as in if you have two 1GB sticks these would, in a four slot board, be inserted in slots 1 and 3 or 2 and 4. The other odd 512MB stick could go in any other slot theoretically speaking. But, you would be better off leaving it out. The SPD chips on the two 1GB sticks should match themselves to time at the slowest common or fastest common denominator.
There is a chance that by having the odd bank population that you said worked for awhile installed as you had, that the MB RAM slots were put under unusual voltage stess. There is a pretty good chance you can remove the 512MB stick, leave the two 1GB sticks in slots 1 and 3 or 2 and 4. But, this is VERY important: consult your board manual or access it online and read what the population requirments are for the slots as in some cases, the two matched sticks go in 1 and 2 or 3 and 4. This little oddity is found from time to time.
Consult your manual or download it and read how the slots need to be populated and stick with the two 1GB sticks.
There are memory testing programs you can find for free at majorgeeks dot com and test your RAM once you have it populated correctly.
In the future, I'd suggest you purchase RAM from Kingston or Corsair directly online as they usually offer a lifetime warranty and this RAM right now for you board is dirt cheap.
Hope this FIXED, as in ANSWERED you question and was more than helpful. Should you feel compelled to rate this solution after reading, either rate it FIXED or not at all. I know its helpful by default, that's what we do here. But only a thorough answer can FIX your situation. You should be fine if you follow my instructions. But, please consult you manual.
Regards,
Worldvet
Nov 20, 2008 | Computers & Internet
Ram upgrades
Does'nt matter which goes where as long as they are all compatible with the motherboard.
Mar 18, 2008 | E-Machines eMachines Desktop PC
Upgrade from 512MB to 1GB
The specs on the memory are correct, so you purchased the correct type of memory for this motherboard. If your getting no video when you power on with the 1gb stick, I would be willing to bet the 1gb stick is bad. Can you return it and try another stick?
Mar 15, 2008 | ASUS P4B266 Motherboard
HP Media Center m7250n (ED842AA) PC Desktop Logo
Top HP Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
